Question about Genie Company Home Security
I have a genie opener model # ISL950/A 1/2 horse opener need to replace remotes what one do i need to get ?
Moved intoo home and no remotes so need advice on witch remote opener i need ?
5 Suggested Answers
Door Tech
  • 98 Answers
SOURCE: 2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Posted on Jan 04, 2009
  • 244 Answers
SOURCE: need to match DIP switchs on a universal garage door remote
I find Clicker products confusing. Might want to buy whole new replacement readio control set. how old is operator?
Posted on Jan 16, 2009
  • 118 Answers
SOURCE: all remotes stopped working on genie opener
Your lock on the opener is probably engauged. On the wall control there is a button labeled lock. Press and hold this button for three seconds. Your remotes should work now. If they still do not work, you need to reprogram the remotes. Press the learn button on the back of the motor and then press and hold the remote button. The light will blink once. Repeat this step on the other remotes.
Posted on Feb 26, 2009
SOURCE: Replacement for Garage Door Remote
The red button is the "learn" button. No resets.
Posted on Mar 25, 2009
Hey I have wolf power air condition at home but I lost the remote of this but here is no model number I need the original remote for it witch work 100% with it do the need full please
contact the manufacturer of the machine and explain what details you have
in many instances the remotes for the same manufacturer for units within a years bracket will work as they are made by an electronics manufacturer and are not changed until an upgraded model is put on the market
Aug 09, 2016 | Heating & Cooling
How to program a remote for a genie garage opener model 209
When programming a genie remote press the learn button
Then you will have to press the genie remote at least three times before it stores the code older genie models 5 times genie i
Apr 05, 2015 | Building Materials
I cannot program my receiver Genie ACSR3 to work with a remote Genie GITR-3
check age difference, every so often the codes change and older parts will not work with newer parts
Nov 03, 2014 | Building Materials
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
Sansui Com
1) try to open the remote.c clean the keypads with contacts cleaner from dirty, corrosion, etc 2) clean the spring contacts batteries, and tight the spring with plier for better contacts ,replace the batteries by alkaline new one. try again.
3) go to Radio Schack or another computer stores and identify the r.control that will be compatible.
God bless you
Nov 01, 2013 | Televison & Video
Entry pad quit working on my Genie Excelerator model #H8000D. Changed batteries.Can this be reprogramed or should I purchase a new one?
The relay on the "unit's" circuit board was causing my light to stay on. If I tapped the unit with a stick the vibration would be enough for the contacts in the relay to open allowing the light in the unit to go out. Call The Genie company; the H8000D Genie garage door opener has a lifetime warranty but only if you are the original owner of your home. If you are the original owner you'll need to have a receipt for proof of purchase. If you don't have the receipt then a copy of your HUD-1 form that you received at closing when you passed papers on your home will be accepted as proof of (original ownership of your home). I have had my Genie H8000D for 12+ years now and so far I have replaced the black indoor wall switch, the out door mounted remote control and both internal circuit boards. After removing both old boards I found that the solder on both ends of one "blueish in color" resistor had come loose from the board because he solder failed. I installed the new replacement boards Genie sent me and the unit works as is should. On the old board the resister didn't look bad so I soldered it back onto the board and I'll keep it for a back up.
Aug 25, 2013 | Genie Company Genie Garage Door Opener...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Feb 07, 2012 | Home Security
Home Security Logo
993 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
