Question about Sony Televison & Video
LNB PS on the screen - Sony Televison & Video
2 Suggested Answers
  • 979 Answers
SOURCE: my t.v flashes a blue bar with LNB PS on it what
I'm guessing that you have a satellite feed of some sorts as that message says that the front end of the system has a power supply problem. Check all connection and modules for proper installation.
Posted on Aug 29, 2011
What does lnb short mean
the cable may have went bad or receiver, but check or replace the cable first
Jul 28, 2016 | Televison & Video
Lightning struck pole outside my home now my tv screen is pink I don't know if it's my tv or cable box!
For sure your TV. But you still have to replace your Antenna Cable, if not the LNB as well.The LNB is the "EYE" in front of the Dish. You do not have to replace the Dish.
Jul 30, 2014 | Televison & Video
Se830 digital receiver
remember to swtich the LNB power to ON in the setting menu.
if still no power, there is a power module on the board. may not be economical to repair
Oct 16, 2013 | Televison & Video
My t.v flashes a blue bar with LNB PS on it what is LNB ps
Aug 29, 2011 | LG Televison & Video
Even Transponderds Zero
Typically that indicates a bad LNB or connection to the LNB. Try moving the line to one of the other three ports on the LNB and if that doesn't work then you will need to replace it
May 18, 2017 | Directv HR10-250 DTV Receiver
We have an old dish network dish and LNB with a new dishnetwork receiver. When we can get the signal up to 5, the screen goes blank and we cannot lock the signal in. Diagnostics state there is no...
Hi mfpayton with the install of the brand new receiver wealways want to make sure all connections are tight. And after all connectionsare hand tight we will need to run the Check Switch Test. It will provide thestrongest signal to your home and you will see the signal move up into the 65percent range. If after the Check Switch Test it still is a low signal we mayneed to check the connections from the Dish and LNB that is an issue we wouldneed to come out on. I will leave the link to show you how to do the CST.http://www.dishnetwork.com/SupportSection/complete-sig-loss
Mike Houston of DISH Network Executive Office
May 02, 2010 | DISH Network 322 DTV Receiver
Changed from single to twin LNB, no signal
HELLO
Here is a suggestion! Try SKEWING the LNB around a few degrees. Looking at the front of the dish, turn your LNB to the LEFT slightly (that is anti-clockwise).
Sometimes it's the little things that matter most where installation is concerned. It is also possible that due to the weight of the new LNB, the alignment may be out.
Nov 21, 2009 | Fortec Star Lifetime ULTRA
I have an exisitng sat that works fine. I bought a 2nd receiver,a dual lnb and a multi switch.Where exactly is the dual lnb installed?
The Dual LNB goes at the Antenna, it "Replaces" the existing one. It Must be aligned EXACTLY right, NOTE the "OLD" ones Placement. the "Switch" wich is a sort of two in One, goes as close to that as practicable... to the Dual LNB, Then through software when setting up you select the "Switch" and then you can control access to either sat. It is a bit of a "Mission" sometimes.. You will have to be very methodical and check all connections etc. I include a link that will help you. http://www.satcure.co.uk/tech/lnb.htm
Nov 07, 2009 | Toshiba Satellite A215-S7422 Notebook
How do i fit a dual LNB so i can change channels
HELLO
A word of warning! Do not attempt to split any feed coming from a single output LNB to another satellite box - you will be asking for trouble!
Now for the solution. If you are using a standard sky minidish you will need a 40mm adaptor kit, a dual output LNB and another length of satellite cable (Webro WF100 prefereably) but I suppose RG-6 will do the job providing it is not too long (around 10-15 meters or so) a couple of F connectors and self-amalgamating rubber tape.
Power off everything! Remove the old LNB and to do this you'll notice a plastic rivet on the LNB arm of the dish which must be removed. When you have done that and the new LNB is place (don't tighten everything yet), connect your current length of cable to one output and the new length to the other (finger tight should be fine) and make sure BOTH of your boxes are connected. Remember to waterproof those LNB connections.
Power on! You should be getting pictures - if not the LNB will need skewing round a bit. Look at the dish from the front and turn the LNB in a clockwise position say the 2 o'clock position - that should do the trick. Then tighten everything.
I wish you well with it - good luck! (:-)
Sep 20, 2009 | Televison & Video
Satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Apr 22, 2008 | DISH Network 301 DTV Receiver
Televison & Video Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
