Question about OKI B6200 Laser Printer
SNMP-reports? Hello. How can I read toner levels from the B6200 via an SNMP-application? And how do I restart the printer from the web interface without losing any settings? (Reset Printer sounds like it will delete more than the print queue, will it?)
4 Suggested Answers
SOURCE: oki b6200 web-interface-login
Log in as root (lower case) and put last 6 digits of mac address in uppercase as password.
Posted on Nov 06, 2008
quannd
SOURCE: oki b6200 printer error
How did it get error? In the most case that error shows the time to replace another Fuser part.
The Fuser was ruined if you print over maximum number of pages (200,000 pages for eg.). If not the component of printer's Fuser is ruined, such as sensor, this is the most case that I have usually seen.
I think it's simple. But how to find it is a little difficult.
Posted on Jun 04, 2009
Joed911
  • 4338 Answers
SOURCE: my printer says set drum/toner cartridge. How?
RESET OKIDATA TONER DRUM
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Posted on Jul 28, 2009
SOURCE: Oki b6200 error code of 006 335
The laser went out. You have to have the ROS replacement kit. I priced it and it was $255 for it. They dont recommend doing it yourself. Its $75 an hr labor.
Posted on Sep 07, 2010
CHECKING THE INK LEVEL
to check the toner level just press the button and wait the second light(orange) to turn On and then release the button. The printer will print two pages one with configuration and one with the supply status of the toner cartridge
Dec 26, 2015 | HP LaserJet 1300 Printer
Error E000024-0001
the E024-0001 is error code related to toner station sensor. It reports this error if sensor cant read the toner level.
As service work, I would say to reconnect the connectros on toner holder unit and connector on toner/developing unit + clean the connectors with antistatic brush because if the toner get's to connector it can cause troubles.
Also try to reinstall the toner tube and turn off and on.
Hope that helps!
Sep 16, 2011 | Canon imageRUNNER 4570 Copier
Is there Liebert NFORM software for normal PC windows 7? and if there please send me A demo .
Liebert ® Nform Software
GUIDE SPECIFICATIONS
1.0 GENERAL
1.2 SYSTEM REQUIREMENTS
A. All material and equipment used shall be standard components, regularly manufactured and available and not custom-designed especially for this project. All systems and components shall have previously been thoroughly tested and proven in actual use prior to installation on this project.
B. The manufacturer will furnish or supply a site-specific Critical Infrastructure Management software system based on customer requirements. The system must be a software-only solution; no substitutions will be accepted.
C. The system architecture shall consist of network interface cards that will be installed in all critical infrastructures that at a minimum support HTTP and SNMP simultaneously.
D. The system shall receive SNMP traps from managed equipment and display the alarm notification in a graphical user interface.
E. The system shall be based on SNMP Open Protocols and integrate seamlessly with Emerson Network Power, Aperture® software suite and Network Management Systems.
F. Open protocol support shall include:
· HTTP(s)
· TCP/IP/v4, TCP/IP/v6
· SNMP v.1, SNMP v.2
G. The system will have the capability of being remotely monitored and managed 24 hours a day, 7 days a week by the manufacturer.
H. The system shall have the ability to be deployed world-wide.
I. The system shall operate as a client-to-server application.
J. The Web interface of each managed device shall integrate directly into the system.
K. The system shall support Enterprise level databases including Microsoft SQL.
L. The system shall support exporting of all recorded parametric trend data.
M. The system shall operate on a server defined by the customer. Specific server brand or function is not permissible.
N. The system shall support virtual server environments by default.
O. The system shall include at no additional cost one (1) year of Software Assurance.
May 09, 2011 | Liebert OpenComms Nform for PC
How do check ink levels on a dell 3110cn
if you use your printer in local network trough the RG45 port, then you must write the printer IP address in some of you internet browsers and there you will see nice web interface, which can support you with lots of info
pifonski
Feb 28, 2011 | Dell 3110cn Laser Printer
Have a canon pixma mp560 every time I print it says printer paused how do i fix
try these steps:
Setting SNMP on the Device SNMP helps monitor the state of the machine and collects information on it. The following items can be set:
<Community Name>: Sets the SNMP community name. You can specify up to two community names. <Writable SNMP>: Enables the computers on the network to access the machine and modify its settings if this item is activated. You can specify this setting for each community separately. <Get Printer Management Information from Host>: Enables automatically the SNMP port monitoring function to obtain printer management information such as information on print applications and printer ports, if you are using Windows Vista and set [Standard TCP/IP port] for the printer driver port. 1. Press (Additional Functions).
Press g0014901.png (Additional Functions). 2. Press [System Settings] 7400rightpointer.jpg [Network Settings] 7400rightpointer.jpg [SNMP Settings].
If the System Manager ID and System Password have been set, enter the System Manager ID and System Password using g0015291.png - g0015292.png (numeric keys), then press g0015353.png (Log In/Out) to enter the System Settings menu. The SNMP Settings screen appears. 3. Select [On] or [Off] for <Use SNMP>.
[On]: When you set or browse each item of the machine with utility that uses SNMP to obtain information. Proceed to step 4. [Off ]: When you do not use an SNMP utility. Skip to step 7. 4. To change Community Name to a name other than <public>, press [Community Name], then enter the community name using the touch panel keyboard.
5. Select [On] or [Off] for <Writable SNMP>.
[On]: Allows the computers on the network to access the machine and modify its settings. [Off ]: The computers on the network cannot access the machine and modify its settings. 6. Select [On] or [Off] for <Get Printer Management Information from Host>.
[On]: Enables the SNMP port monitoring function to automatically obtain printer management information such as information on print applications and printer ports if you are using Windows Vista and set [Standard TCP/IP port] for the printer driver port. [Off ]: Disables the above function. 7. Confirm the settings you specified, then press Turn off the machine, wait at least 10 seconds, then turn it on. [OK].
8. Press [Done] repeatedly until the Additional Functions screen closes.
9. Restart the machine.
Nov 06, 2010 | Canon imageCLASS MF7480 Laser Printer
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
Hello , my oki b6200 display error replace fuser E. How to clear fuser counter.
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jan 04, 2010 | OKI B6200 Laser Printer
My printer says set drum/toner cartridge. How?
8. Restart printer.
Jul 28, 2009 | OKI B6200 Laser Printer
Hello, I am in Brazil, and my Canon ImageRUNNER C3220, is the problem of off alone, just off the digital display but not print anything when it is so, the technicians who were found not fix the problem,...
If the printer appears as offline in windows, consider disabling SNMP monitoring. Sometimes SNMP falsely tells windows that the printer is offline for events like "toner low, replacement not needed" and "low paper, drawer x"
Go into printers & faxes, right click on your printer and select properties, go to the ports tab, press configure port, un-check SNMP Status enabled.
Mar 03, 2009 | Canon imageRUNNER C3220 Printer
Oki b6200 web-interface-login
As menttiones on Manual
The factory default of Administrator Name is “ADMIN” and Administrator Password is “xxxxxx” (the last six characters of the printer MAC address).
Alan
May 05, 2008 | OKI B6200 Laser Printer
OKI B6200 Laser Printer Logo
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
