An error occured while setting scanner properties
2 Suggested Answers
vonnielsen
  • 169 Answers
SOURCE: I installed the Vista Drivers
Install the latest drivers from the website. To download:
1 Go to hp.com 2 Click on Support and Drives 3 Enter your product name or number, in this case just type in Officejet 8500 All-In-One 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
But before Installing the Software, use the Disc that came with the printer so you can do an L3_Uninstall first.
To go for an L3_Uninstall:
1 Go to My Computer (XP), Computer (Vista and Win7) 2 Right Click on the Driver CD, The one that has the HP Logo 3 Open Util 4 Open CCC 5 Double Click on the icon that says Uninstall_L3
The Uninstall will prompt you to restart the computer once it's done. After doing so, Install the newly downloaded software.
Try scanning again, I hope this worked. :)
Posted on Feb 04, 2011
Tip
External monitor out of range error on Dell Latitude E-Series portable
If you have trouble getting a display on an external monitor, the issue can be resolved by making the proper settings in the Video Driver Control Panel applet, instead of the Windows Display Properties.
The issue occurs when the display settings for the external monitor are set higher in the NVidia Control Panel than the monitor could display. The settings overrode any Windows Display Properties setting. Similar issues have been seen with the Intel GMA Graphics Controller.
These issue occur docked or undocked with a variety of external displays, projectors and TVs.
So remember that the NVidia and Intel Control Panel settings override the Windows Display Settings.
on Mar 25, 2010 | Computers & Internet
Printer is in use or an error has occured check status scanner driver will be closed closed
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Use a test print to CALIBRATE the scanner. if this wont help there is fault in the motherboard.
Nov 12, 2011 | Office Equipment & Supplies
I installed the Vista Drivers for my HP 4070 scanner and it gives me an error that "An Error Occured while Setting Scanner Properties. If another program is scanning, please wait for it to complete...
Feb 03, 2011 | HP Scanjet 4070 Flatbed Scanner
The error message "an error
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Jan 28, 2011 | Panasonic Computers & Internet
Problem installing broadcom netxtreme gigabit NIC in windows server 2003 R2 standard, the driver doesn't load, error code 38
Determine Correct Driver Click Here
1: Uninstall any unwanted programs.... (make sure/Try to Clear your Hard Drive more than 50% as free)
2: Update virus software
3:Restart Computer IN Safe Mode
4: Run Virus Scan
5: Restart in Safe Mode
6: Uninstall Existing Driver Software From Device manager
7: Restart computer in normal mode
8: Start>Run> type %temp% and hit run.
9: Delete all files in this folder....
10:Restart Computer
11: DEFRAG
13: Restart COmp.
14:Install Driver
>Troubleshooting for Error 38
The error message for this error appears as: "Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory."
This error occurs when a previously loaded driver is preventing the new driver from loading. To fix this error follow these instructions.
  • Reboot Your PC
  • Open the Device Manager and in the device Properties box, select the General tab.
  • Properties Uninstall(Right Click Mouse) / Disable(In Property)
  • Restart PC
  • reinstall /enable
  • Once you have followed the instructions throughly, reboot your PC
Hope this make you Better Conclusion....Thanks for Using FixYa.....
Apr 21, 2010 | Computers & Internet
Windows Mobile Symbol Find WLAN error
Warm boot the MC55 if that doesn't help then cold boot it, if that doesn't help then reload the Operating system, if that doesn't fix it then send it back to Motorola for a warranty repair.
Jun 02, 2009 | Symbol MC9090 Barcode Scanner
Scanjet 3300c does not work in WindowsXP
I had the same problem and was having no luck with suggested solutions from HP. But the following procedure did work for me. It disables WIA, the built in XP scanning software. See http://forums13.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1280600613997+28353475&threadId=124494
1. Right click My Computer.
2. Click Manage.
3. On the left, click the plus sign on Services and Applications.
4. Double click Services.
5. On the right side, scroll down to Windows Image Acquisition (WIA) and right
click.
6. Click Properties.
7. On the General tab, set Startup Type to Disabled.
8. Click OK.
9. Exit Computer Management.
Mar 19, 2009 | HP Scanjet 3300c Flatbed Scanner
FI-5120c
Invalid orientation/long scan combination. Check the KScan ScanDirectionCap and ScanContinuousCap properties and set ScanDirection and ScanContinuous accordingly is for error 20080 and for 20090 means Peripheral stopped by user. Stop button was pressed.
Jul 31, 2007 | Fujitsu ScanPartner fi-5120C Pass-Through...
519 people viewed this question
jasbo
jasbo
