Question about Asrock K7VT4A-Pro Motherboard
K7vt4a Pro and Athlon 2400+ shutdown with XP
I have setup a new system with the ASRock K7VT4A Pro and an Athlon 2400+ cpu. I have a dual boot system with Windows XP and Linux Debian Lenny. I have the annoying problem of the system shutting down and rebooting in XP. But no problems whatsoever in Linux. I even reloaded WIn98 and still no problems. I was thinking the cpu might be a problem but it doesn not shutdown in Linux or Win98. Only Xp. My dad has the same board and has a boat load of his own problems but not the shutdown. We're both reverting to Win98 until we figure why XP is such a problem on this board. (I only use Windows for games anyhow). And I've tested with the basic hardware and multiple configurations to isolate the problem and no one hardware item seemed to make a difference.
  • 1 more comment
  • cage47 Oct 28, 2008
    Doesn't have anything to do with the dual boot. It does the same with another hard drive with XP loaded alone. It's just reference that in Debian I don't have any performance problems. But what I do is load xp. Load the board's onboard sound drivers. Load the install for my ATI Radeon 9000. Then load a big game like my old XMen II. It will go for about 5 minutes (not the exact time just a rough estimate) Then the system just reboots. Occasionally it comes back on reboot saying the system has recovered from a serious error. It gives me a few suggestions. I have tried to isolate them with no luck (bad memory, replaced all mem chips, bad cpu, replaced cpu, bad hard drive, used multiple hard drives). Again I do not have this problem with Linux. But checking somewhere else I wonder if the 4x1 via chip drivers not being loaded has anything to do with it. I'm going to try that tonight and see if it makes a difference. Im presently testing on the hard drive with XP loaded alone.
    I've also tried 2 other power supplies. 1 from an HP Pavillion and another spare. Same problem. I am almost wondering if I have problems with my cpu. I've got a second one coming to try again. That is the last thing I can think of.
  • Frank
    Frank May 11, 2010
    which operting system did you installed first. dependent on which OS first the dual boot porcess are different.
    I am assuming you installed the Windows Xp first, since it try to boot to Xp on restart.
    clarify, and need little more information on how the boot menu is constructed.
    Genius:
  • 1,605 Answers
OK
soud like the chip set may be in question.
chenck the power supply also, it may be recycling.
Posted on Oct 28, 2008
A im trying to start a pc but my monitor is not startin.Asrock K7VT4A-Pro Motherboard . led red is on and my grafic card is ok
Hi, you can download a manual here:
http://asrock.com/mb/manual.asp?Model=K7VT4A PRO
Here you also find drivers.
You may have to unzip the file before installation.
Do you use the right type of ram ??
The ram module could have a defect.
Have you insertet the cpu properly ??
You can maybe try with another AGP graphic card.
Or the card is not insertet in the slot properly.
Remove the graphic card and try to clean the contact points
on the card with a piece of paper.
I guess its just a bad connection or the card is defect.
You can read all about that red led in the manual.
Aug 31, 2011 | Asrock K7VT4A-Pro Motherboard
Tip
Asrock K7VT4A PRO
please help i need procesor socket A (462) Athlon XP 3200+ 2400MHz 333MHz 512KB n/a ....
on Dec 19, 2008 | Asrock K7VT4A-Pro Motherboard
My asrock k7vt4a-pro motherboard did not detect IDE hard disk whats the problem
The disk has died and everything on it is lost. Junk it and install a new one.
Jul 07, 2010 | Asrock K7VT4A-Pro Motherboard
Sata on k7vt4a-pro. wont boot into windows with any dvd drive in sata plug.does motherboard support sata dvd drives
not usually No.
You need to setup the Pc with an IDE drive First. Then load The Sata drivers, usually on the setup CD. ( obtained with motherboard )
Alternative, is to create a SATA/Raid boot Disk et,c.
Mike @ compurepair.
Nov 04, 2009 | Asrock K7VT4A-Pro Motherboard
Got k7vt4a pro need sound for vista not find it on the internet
Sorry pal but your motherboard audio device only supports winxp operating system and below. There is no device driver for it that can run windows vista. My suggestion is that buy a new audio card that will support windows vista and above.
Nov 01, 2009 | Asrock K7VT4A-Pro Motherboard
Ive formated window 2002 the sound was remove what audio compatible to k7vt4a
Follow the link provided, select your operating system and look for
C-Media audio driver ver:UDA046_build02
http://www.asrock.com/mb/download.asp?Model=K7VT4A%20PRO
Google Search Terms: K7VT4A-Pro drivers I'm Feeling Lucky
Oct 27, 2009 | Asrock K7VT4A-Pro Motherboard
K7VT4A PRO
This will probably fall on deaf ears but that trident is probably an old 3.3v card and you can only use a single "keyed" 1.5 video card in this motherboard. its also not worth risking a 3 keyed "universal" video card in this board as so i heard they sometimes try and draw 3.3v instead of just 1.5v that they are supposed to be able to step down to hence the name "universal" agp (having both 3.3v and 1.5 volt keys)
Maybe this solution will help future second hand purchasers of this motherboard since they are still out there selling to this very day.
Nov 03, 2008 | Asrock K7VT4A-Pro Motherboard
Asrock K7VT4A-Pro Motherboard Logo
183 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
