Question about Kenmore Elite 45986 Front Load Washer
Knocking My Kenmore HE3 is about 3 years old. There is a load knocking noise when the barrel turns. I have made sure that the machine is level and cleaned the gunk from under the rubber. Any thing else I can do before calling the repairman?
  • burns841 Oct 29, 2008
    thanks. I will give that a try!
  • burns841 Nov 02, 2008
    Okay, I did everything you suggested and there is still a knocking sound. It appears to be on the right side of the machine when the barrel rotates. Any other suggestions?
    President:
  • Kenmore Master
  • 2,651 Answers
You can remove the lower acess panel (3 screws across the bottom of machine)i would then check to make sure all 4 of the suspension supports are still connected, if so perhaps you can run with panel off to get a better understanding as to where the knock is coming from.(topp panel can be removed (3 screws across the top back) toalso look from atop for source of noise.
Posted on Oct 29, 2008
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
My GE front load washer is banging during the spin cycle?
Reminds me of a old car I used to have lol
sorry about that.
Try making sure your load is spread evenly inside.
If it is then and it's perfectly level the the barrel is out of balance
you would need to pull it apart to see where it's knocking.
Sometimes it's as simple as getting a spirit level and just levelling it off both front and horizontal
Jan 11, 2014 | Washing Machines
My Kenmore model # 20642 991 leaks water when it spins (mostly with large loads) and the barrel inside seems to be loose or something because it bangs hard against the inside - sounds like the whole...
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub. The banging noise is due to being unbalanced. You may need to replace the balance ring on the top of the drum inside the washer. Watch this Video to see if this is how your machine is acting.
Nov 26, 2010 | Kenmore Washing Machines
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE3 washer started knocking and shaking during spin.
indicates that the tub support rods have failed at the air dampners
the fix is new rods from the service agent spares and a re levelling if the tub ,not the machine
Nov 20, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Loud knocking noise at end of spin cycle
Have you checked the wire harness ,because the tapping of just 2 wires hitting the cabinet is overlooked alot.The noise just 2 wires makes simulates a hammer knocking inside.If the problem isn't escalating than check to see if your tub support arms are all tight.There are 12 of them.
Jun 12, 2008 | Washing Machines
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader model 417.29042992
check and make sure the washer is LEVEL otherwise when in spin, it may "walk" across the floor. also if it's not level then the tub will "tilt" in one direction and may contribute to the thump, thump.
Aug 23, 2007 | Kenmore 43042 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
170 people viewed this question
Sal De
fordexpert
Robert Rankin
