Question about Dryers
Frgidaire dryer help
Mike thank you for the quick reply. I got the old vacuum out and openedthe front of the dryer and vacuumed everything. I see where the problemis when I look into the dryer in the back where all of the holes arethere is alot of lint build up but it wont vacuum through the holes andI can't figure out how to get to that spot. Do I have to take the wholeback off the dryer? I have a frigidaire laundry center with the dryeron the top. Thank you again for all of your help!!
  • 156 Answers
SOURCE: Kenmore Laundry Center #417.90802990
unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Posted on Feb 28, 2008
  • 489 Answers
SOURCE: front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Posted on Apr 28, 2008
  • 413 Answers
SOURCE: Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Posted on Jun 26, 2008
SOURCE: My Frigidaire FEQ1442ES1 dryer has started to beep
When I read to manual, it said it was the lint. I use a paint brush to brush the lint off and usually the beeping stops.
Posted on May 05, 2010
  • 2605 Answers
SOURCE: I have a Bosch Nexxt electric dryer. The lint
Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting, but I can narrow it down to two probabilities based on your description.
To save time and back and forth dialog, I`ll mention the most likely and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here first**
There is an auto shut off or emergency kill switch next to the motor which will prevent it to start in the event it was tripped for whatever reason.
It will look like this image below and all you need to do is push it to the right ( from the back )...
If you`ve already taken the back of the dryer off to gain access you should have no problem.
Either Scenario I alluded to ( the other would be resetting the hi-limit cut out you already referred to, you can see through the back vent opening when the vent is removed and then by pushing the red button in...shown below ) will require the removal of that panel so let me know if you require further assistance to do this.
Keep me posted how you make out or if anything is not clear.
Thanks for choosing FixYa and good luck.
Macmarkus :)
Posted on Sep 30, 2010
Testimonial: "Got it working!"
Hi, i am mike. i have a bissell model #6585. the power cord has broken off from the housing. h;;ow do i get the housing apart to reconnect the wires. thank you
Hi Mike! You'll want to contact one of our Authorized Service Centers to have one of our techs inspect your vacuum.
Here's a quick link:
Apr 19, 2013 | Vacuums
I lost a piece of my vacuum cleaner in the machine!!!Was vacuuming out lint. How to remove the front panel and access the vacuum part? I assume there are clips? Thanks, Judy
Unplug dryer.Pry up front corners of lid with flat blade screwdriver. Lift lid. It should hinge on back Push down firmly to close.
Apr 04, 2012 | General Dryers
My maytag neptune MDG5500AWQ will heat only on the wrinkle release button. How do I get the front off to clean out the lint. Can't get it with the vacuum. please advise
Here is a good link that will tell you what you need to know. I purchased and inexpensive kit from lowes that has vacuum attachments that will reach into very small cracks and crevices. It has been a very helpful item to have.
Make sure to check the vent on the outside, and the ducting that runs through the wall.
Be very careful, some of the places are very sharp, might be wise to wear some gloves, and be mindful of any wiring you could run into.
Hope that helps,
Jul 20, 2011 | Maytag Neptune MDG5500AW Gas Dryer
G4 Kirby Vacuum Cleaner motor is slow and over heats
Hello, gs
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about vacuumcleaners and possibly yours, from
repair to trouble shooting it.
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
Nov 29, 2010 | Kirby G4 Bagged Upright Vacuum
Can i get new motors or the old one repaired
Yes we can try to find a new motor for your vacuum cleaner, but first of all you need to provide us the brand and the model number of your vacuum cleaner......
Please reply........
Mar 20, 2010 | Vacuums
Kenmore dryer model 76901690 76901 how do i remove the front to clean lint the dryer wont heat up want to clean to see if it is problem
remove the back and check for thermal fuses it might have blown. usually theres a toe panel u can open
Feb 12, 2010 | Dryers
My 1999 chevy blazer 4wd just quick working it engages but doesnt work? please help need answer fast
Check the actuator under the battery. make sure that it's working and pulling on the cable to lock the front hub. If it is and the front wheels are not locking then the clip at the front pumpkin (differential) may be broken or the fork that engages the axle. If everything looks good and the actuator is not working, inspect the vacuum line to the 4wd vacuum switch on top of the transfer case (drivers side) and then work your way to the vacuum line to the engine compartment. There is a T vacuum line by the ABS unit on the drivers side and inspect the lines there and the vacuum canister in the fender. Good luck and keep me posted and hope it's a simple vacuum line that went bad and not the front pumpkin.
Feb 02, 2010 | 1999 Chevrolet Blazer
How do I get the front lower cover off my Kenmore dryer? I want to vacuum the lint.
pop it off with a screw driver on the two side there are 2 clips thank you for useing fixya
Apr 25, 2009 | Dryers
Front wheel problem
I would send it to protechrobotics. they will test all your components and let you know what needs to be done. if the repair is more than it's worth--they will help you out too.
Apr 07, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuum line Diagram 1995 Grand Cherokee
Hi Terrell,
Sorry about the delay answering your request. Been out of touch for a few days.
That vacuum line is almost certainly the problem. Good tracing.
It should be attached to a Manifold Vacuum port. Same area as Cruise and Climate Control.
Diagram coming up.
Oct 26, 2008 | 1995 Jeep Grand Cherokee
Dryers Logo
19 people viewed this question
Top Dryers Experts
