Question about GE Refrigerators
My TFX20jr TFT20jr Ge 19.7 refigerator/freezer stopped making ice?
The TFX20jr TFT20jr stopped making ice, not sure what the problem may be was working fine and then yesterday just stopped?
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
Vish2
  • 74 Answers
SOURCE: Kenmore Refigerator Ice maker
First, ensure that you have water connected to the intake tube at the back. The water filter needs to be checked also. It is in the cooling section(not the freezer), at the top. If it looks old or water does not flow, it will need replacing. Depending on the model, there is a switch inside the freeze section behind the ice tray. Turn that on, and ice should be available after a few hours. Some models don't have a switch, but a wire hanger, that needs to be in the down position for the ice maker to work.
Posted on Aug 30, 2007
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
  • 4 Answers
SOURCE: GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Posted on Jan 01, 2009
My kenmore refigerator ice maker stopped making ice.
Could be that the solenoid that feeds water to the ice maker is not working properly.
Also make sure that the freezer temp is at least 10 degrees or less - if not the ice making cycle will not commence.
Mar 12, 2017 | Kenmore Refrigerators
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
Ge tfx20jr icemaker not working
First check that ice maker is on. Check ice maker water valve and make sure freezer is freezing. Is there ice in the ice maker? If so its not harvisting replace ice maker
Aug 22, 2013 | Refrigerators
Our Refigerator is forming ice in the freezer. It
Probably has lost the defrost function and excess ice has formed clogging air flow and shutting down ice production. Remove the access panel and inspect the evaporaton department for signs of failed defrosting.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2010 | Refrigerators
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Ge tfx20jr side by side
make sure your freezer freezing if freezing check water valve check icemaker
Mar 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Frig mod#TFX26KPDA
More likely, the defrost system has failed.
There are three components: Defrost timer, a defrost heater, and a defrost bi-metal.
The timer can be located either in the food compartment, on the rear of the unit, or behind the kickplate. The heater and bi-metal are located behind the freezer rear wall (or freezer floor, depending on design). It's easiest to unplug the fridge overnight, with the freezer door open, to melt all the ice that has developed. PRIOR to doing all this, please ensure that there IS ice forming on the wall of floor of the freezer! Let me know. I hope this helps!
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
