Question about Brother DCP-8060 All-In-One Laser Printer
Dcp-8060 brother machine error
Mix-it-up
  • 832 Answers
SOURCE: machine error A7 ( brother dcp 115c )
Did you change the scanner cover? This happens when a wrong cis type is installed. The rom data has to be set again (this can only be done by service personal)
Posted on Nov 10, 2007
Soulvisitor
  • 1113 Answers
SOURCE: I need total reset for a Brother dcp 115c
Your print head is stuffed. More expensive than new machine, Release your frustration with this unit by placing neatly in bin!
4F
The head drive voltage has
dropped from the high to
low level in an abnormally
short period.
why
Piezoelectric (PZT)
ceramic actuator
defective (Cracks or
rare short)
Posted on Feb 07, 2008
SOURCE: Help needed
If you open up the cover there are two little covers in there lift the long one out. It should have a thick white wire in it make sure it is plugged in. I had the same problem for two days and finally figured it out hope it works.
Posted on Dec 08, 2008
xptareq2000
  • 1447 Answers
SOURCE: The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Posted on Nov 22, 2009
  • 60 Answers
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Posted on Feb 03, 2010
When printing on my DCP-8080DN, I am getting a thick black line
Try this:
Clean the inside of the machine and the corona wire in the drum. If this does not solve your issue, replace the drum. Also, the paper tray ground terminal in the machine body may be dirty.Clean the contact with a dry cloth.
Jun 17, 2011 | Brother DCP-8060 Laser Printer
Brother DCP 8060 is displaying drum near end what does thic mean
After approx. 25000 pages you should replace drum unit
This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
This message would continue to appear if the drum counter was not reset when you replaced the drum.
To reset the drum counter, follow the instructions below:
  1. Open the front cover.
  2. Press the Clear/Back key.
  3. Press 1 to reset.
  4. Close the front cover, pressing firmly on each side until they click into place.
Oct 04, 2010 | Brother DCP-8060 All-In-One Laser Printer
Toner lekage in TN3145
Is sounds like you have a defective Toner Cartridge- Remove & Replace before you machine sustaines damage.
Jul 08, 2009 | Brother DCP-8060 Laser Printer
Brother dcp 8060 reinstall paper tray error message
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function CenterĀ® DCP-8060...
Brother DCP-8060 All-In-One Laser Printer Logo
344 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
