Question about La Crosse Radio Controlled Atomic Clock
Our radio controlled clock (Alba) has been running 8 hours sloww all day. We pressed small red reste button on back and hands are now at midday and doing nothing. How long should we wait to see if it rights itself? is there anything else we should do?
3 Suggested Answers
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
  • 9 Answers
SOURCE: Resetting to daylight savings time.
The clock is searching for a strong enough radio signal from NIST station WWVB. When it can't lock on it, it gives up, moves the dial four hours, and goes to sleep to wait for better reception. Put the clock in a window facing towards Boulder, CO, overnight. (Radio propagation is better after dark.)
Posted on Mar 09, 2009
I dont no how to set the timer to 24 hr clock
change to 12 clock
however a 24 hour clock has the same times up to midday -- midnight to midday --- the hours are 1 to 12 oclock after midday you take 2 off the reading and it is the same time as a 12 hour clock
so 1300 is 1 o'clock, 1400 is 2 oclock ,1500 is 3 o'clock
1800 is 6 o'clock 2400 is midnight
the minutes are the same regardless so 1.30 is 1.30 after midnight or 1330 after midday or 1.30 after midday now for example --if you want the timer to start at 6am you set the timer to start at 6 am to switch off at 8 am set switch of at 8 am
it you want the timer to start at 6 pm set it at 1800 and switch off at 10pm set it at 2200 hrs
Jan 22, 2017 | Hardware & Accessories
How do I set my lacrosse clock ws8055u
Press and hold Set (the top button on the right hand side of the clock) for 2+ seconds to enter the Programming mode. If the unit hasn't been set before "-5EST" should start flashing. Press + (the second button from the top) until the correct time zone is displayed. Press Set to save the setting and advance to the next program option. Again use the + button to set DST on or off. Press Set again to save and advance to the language choice (for the displayed day of the week). Press + to go through the choices and then press Set. Repeat the above steps to set the hour (if the clock didn't get the correct time from the WWVB radio). Note: PM will be displayed for the afternoon hours. There is no indicator for AM hours. Press Set again to save and advance to the Minute setting. Pressing Set again will bring the unit to set the Year, then advance to Month, then Date. The next press of the Set button will advance to setting the day of the week. The next items to set are the 12/24 hour time display and the units for the temperature.
If you press Snooze, on the top of the clock, or do not press a button within 15 seconds, the clock will exit the Programming Mode. LaCrosse has the manual for the WS-8055U on the product page: http://lacrossetechnology.com/8055/ . The direct link to the manual is http://lacrossetechnology.com/8055/manual.pdf . Make sure to replace the 2 AA batteries and position the clock where the radio signal is strong if the clock doesn't maintain the correct time.
I hope this helps.
Mar 16, 2015 | La Crosse Technology Radio-controlled...
Need to reset atomic clock to Virginia time zone; now 4 hours ahead
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
May 31, 2012 | La Crosse Radio Controlled Atomic Clock
Have lost instructions for lidl radio controlled clock and it has not reset hour back
Hello
You haven't given any details about your clock, ie, its Model number, brand name etc. Yet I posts this solution, as these are the genteral proceedings to reset a radio clontrolled clock.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time. OK.
Oct 31, 2011 | Audio Players & Recorders
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
Second hand has stopped working. Stopped on # 11. Have tried new battery and resetting clock by reinserting battery. Sometimes second hand will work for a limited time. Clock keeps good time with hour and...
Hello
Just setup the clock once again by replacing the battery and check. If this also does not help you, the the press fitting of the second is loose. you have to open it to make it pressed firm.
OK.
Jul 03, 2011 | La Crosse Radio Controlled Atomic Clock
I plugged in my Emerson Smartset Clock Radio (model CKS2005) and the date is off by a couple. Today is August 4, Thursday, and it states August 7, Saturday. How do I change the date? The date button is...
You have to run the clock back. Press Time/Date and then press up or down after you run it 24 hours the date will change, and the date will move day to day.
Aug 05, 2010 | Emerson Smartset Clock Radio
Mar 08, 2009 | La Crosse Radio Controlled Atomic Clock
Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Mar 17, 2008 | Refrigerators
La Crosse Radio Controlled Atomic Clock Logo
457 people viewed this question
Top La Crosse Home Experts
John
John
Are you a La Crosse Home Expert? Answer questions, earn points and help others
