Question about LG Dryers
Thermal fuse on lg dryer dle2516w
Thermal fuse replacement
Jimster
  • 240 Answers
SOURCE: replacing thermal fuse on dryer
Would need to know what type of unit you have and a model number. On most Kenmore and Whirlpool models they are mounted on the heater box itself. Depending on the type it could be inside the rear panel, or mounted on the floor of the unit. On Frigidaire and other models it mounts to the element case in the rear. Maytags also mount to the element box on the top left inside. Most of the time they have a couple of different looks. On Whirlpool and Kenmore, they have 2 wires running to them, and usually sit away from the thermostat. If its inside the rear panel of these units, it will be towards the top by itself, and could be white or black depending on the age, round or sqaure. On GE, Frigidaire, and their look a likes, it will be small and round, with two wires going to them as well. Most of the time these are metallic in color. Maytags can be black or mettalic, and sit on the sides of the boxes. If this doest help you, please get me the model number and make of unit, and will tell you right where its at. Good Luck!!!!!
Posted on Feb 03, 2008
dniro592006
  • 121 Answers
SOURCE: LG DLE7177 Thermal fuse
Thermo Fuse is normally followed by the power source or on
the circuit board, Follow power source and you will find fuse.
Posted on Apr 02, 2009
  • 52 Answers
SOURCE: NEED TO REPLACE HEATER ELEMENT
You should be able to take off the back panel and see it. The heating element is USUALLY an easy fix. Let me know if you need any further help.
Posted on May 04, 2009
  • 108 Answers
SOURCE: lg dryer dle2516w doesn't heat up. everthing works
the heating coils may be burned out.
Posted on Dec 22, 2009
SOURCE: Maytag electric dryer Model-Pye2300AZW did
The air flow past the thermal fuse is too hot. The air flow cools the heater coil area. Check the air passages from the lint filter to the heator coil housing for lint balls blocking the flow and letting the area around the fuse get too hot.
Posted on Dec 01, 2010
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
Lg dlex7177wm heating element
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
This is a specialised job and should only be attempted by technically competent persons.
Mar 13, 2014 | LG DLEX7177 Dryer
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
Electric dryer will not start
Maybe a defective start button?
Nov 05, 2013 | LG DLE2516 Electric Dryer
Dryer runs normal but with no heat, is there a reset button or fuse? It is a DLE2516W
pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minute operation if you can get to the right side access port.
Jan 16, 2011 | LG DLE2516 Electric Dryer
LG Dryer DLE2516W contiuously trips breaker but only on heat setting greater than low
Your circuit breaker may be bad. Run dryer and if breaker gets hot after 10min or so the breaker is bad.
Higher heat settings draw more amperage thus tripping the bad or undersized breaker. 30 amp 2 pole breaker required.
Ck. the power cord for signs of arching. Replace power cord or outlet if damaged.
Jan 04, 2010 | LG DLE2516 Electric Dryer
May 04, 2009 | LG DLE2516 Electric Dryer
Oct 21, 2008 | LG DLE7177 Dryer
Dryers Logo
56 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
