Question about Panasonic Panafax UF-790 Plain Paper Laser Fax
Panafax uf-790 - info code = 001
WHAT IS CODE 001?
  • 134 Answers
SOURCE: panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Posted on Jun 14, 2008
  • 134 Answers
SOURCE: Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Posted on Mar 25, 2009
FixinFax
  • 3085 Answers
SOURCE: Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
Posted on Jun 04, 2009
FixinFax
  • 3085 Answers
SOURCE: panafax uf-322 info code 016 carriage cannot move
No simple fix.
Open the top cover, turn machine off.
Move the ink carrier to center, knock off the tower of dried ink with a letter opener.
Oil the chrome shaft.
Clean the plastic strip in back of the ink cart with soapy water.
Posted on Oct 06, 2009
Testimonial: "Thanks, FixinFax, kind of you to reply!I found some similar advice, and used my husband's elec razor disinfect/lubrication solution to do the cleaning"
FixinFax
  • 3085 Answers
SOURCE: Info Code 060 on our Panafax UF 885
Code 060 means that the toner door is open. Check the switches.
You might have to tape the door closed on the rear side or call a technician to replace the door.
Posted on Nov 25, 2009
ERROR CODE 041 ON PANAFAX
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Jun 15, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
How to reset access code without the access code?
Unplug the machine from the rear
Hold down the ENERGY SAVER key while plugging the machine back in
scroll down to SHIPMENT SET
press SET
wait for the machine to reboot
Mar 05, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic Panafax UF-790 Fax did not complete logging into memory. Comm. Journal comm. 212 What do I do?
its a receiving error code means a computer was trying to fax you and it didnt connect properly
Nov 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Fax not going through-Info code 503 coming up
PHONE LINE DISCONNECTED. Check the phone line with a regular phone.
Feb 26, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
We have a Panasonic Panafax UF-790
It could be a refilled Kyocera KM-F650 cartridge in a Panasonic UG-5510 box.
They look identical, but are configured differently.
You need to try another cartridge as it appears it is not a machine problem.
Dec 30, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic uf-790 keeps telling me that there is no cartridge info code 45
sounds like you have a bent toner sensor. turn the machine off and take the toner out and place on the side
what you could try to do is grab a piece of paper fold it in 4 like so
__ __
|__|__|
|__|__|
then rip one piece off and fold that 5 times over it self.
look into where the toner goes in the middle you will see a silver bracket with a black round piece of plastic on the top left conner you need to put that piece of paper under that coner where the black circle is and turn the machine back on then put the toner in.
if this does not work you need a tech to look at it
Oct 20, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Panafax uf-790 - info code = 011
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Panafax uf-790
First see if you plugged the phone line into the line jack and not the extension or answering machine jack, Sounds like it is not plugged into the LINE jack.
Thats the most frequent problem when you can fax out but not in.
Nov 08, 2007 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic Panafax UF-790 Plain Paper Laser Fax Logo
20 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
