Question about Brother MFC7360N AllInOne Laser Printer
Toner needs replaced or memory is full on brother mfc 7360n
5 Suggested Answers
  • 4 Answers
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
Posted on Oct 21, 2009
  • 13433 Answers
SOURCE: Message on Brother MFC
Open door
press Clear/Back key
press *00
press OK
Do not choose anything for drum replacement. when drum replacement menu comes up, just press the * and then 00, then just press OK.
that should clear the error message, the printer has a toner life counter that needs to be reset.
Posted on Oct 04, 2010
SOURCE: Drum on Brother MFC-9840CDW needs replacing less than 9 mo later.
press the 3 and 9 button at the same time in ready mode.
then the reset menu will appear, press the up or down arrow until you get to drum.
press ok,
and select 1 to reset or 2 to exit.
it will return the ready state and your done.
Posted on Feb 08, 2010
Samyfam
  • 379 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
How to repair head laser brother 7360
you do not repair them-- just replace
you can reset the error code if needed
Feb 16, 2015 | Brother MFC 7360N - Multifunction fax /...
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
My MFC-7360 says NO PAPER, but there is paper.
Most probabply will also say Please put paper in the MP tray ?
Sep 23, 2014 | Brother MFC 7360N - Multifunction fax /...
Reset brother toner counter mfC 7360N
If you are using refilled products then your re-manufacturer needs to reset the cartridge. For these there is a particular gear placement to allow the toner sensor to reset. If you are using Brother Original products then the brother helpdesk should talk you through this.
If you are filling your own cartridges well any issues you have with this reset process are at your own risk.
Once you have completed the reset process go to the brother website and download the latest firmware update for your machine as this will alleviate most of the issues with cartridges not being correctly set.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:10.0pt;"Times New Roman";}
  1. Open Front Cover.
  2. Display reads "Front Cover Open"
  3. Press the 'Clear' button
  4. Display reads "Replace Drum"
  5. DO NOT RESPOND TO THIS MESSAGE. Press '*, 0, 0' on the keypad.
  6. Press 'OK'
  7. Close Front Cover.
your machine should now be ready to print.
Aug 31, 2014 | Brother MFC 7360N - Multifunction fax /...
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
Why is there a black line on copies when pages scanned with automatic document feeder but fine when using the flatbed scanner?
Different paper path, the MultiFunction unit is dirty - Most likely toner inside the roller or paper path. Try a laser cleaning cloth that you can buy in some stores or online. Search: Staples
Aug 05, 2014 | Brother MFC 7360N - Multifunction fax /...
Brother manual feed insert paper
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347
Description of Problem 100000012720
When I try to print from Microsoft Word or another program, I receive a message stating: Manual Feed, No Paper, or Load Paper XX. What can I do?
Brother Software Technical Support
Jun 29, 2014 | Brother MFC 7360N - Multifunction fax /...
Clear the toner low message on my brother 7360n
I opened the cover door, pressed the clear button, but entering *00 didn't work for me but entering *12 did.
Apr 24, 2012 | Brother MFC7360N AllInOne Laser Printer
Brother mfc-7360n Toner low reset
just change the cartridge or refill it again with the proper toner,else u have fault at the toner sensor or the toner itself,else u have no connection between the cartridge and the M/C DC controller, else your M/C DC controller faulty
Jan 06, 2012 | Brother MFC7360N AllInOne Laser Printer
Open Questions:
See all Brother MFC7360N AllInOne Laser Printer Questions
Brother MFC7360N AllInOne Laser Printer Logo
2,126 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
