Question about Garden
What kind of oil does flotec electric water pumps use?
What kind of oil is inside the pump? I spilled it when I took the pump apart.
  • 10 Answers
SOURCE: pump works but is not pumping water
IT SOUNDS AS IF THE PUMP IS NOT PRIMED. MAKE SURE THE THE PUMP IS FUL OF WATER
Posted on Jan 11, 2009
MrScary66613
  • 1990 Answers
SOURCE: motor running but not pumping any water, why?
You very well could have a bunch of Sediment on the Intake for the Water OR The water table has Drpped Below the Pump.
Posted on Jan 19, 2009
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
  • 634 Answers
SOURCE: Pump is leaking oil
very iffy to get to seal properly and for the $40 bucks cheaper to get new one
Posted on Jul 17, 2009
  • 1114 Answers
SOURCE: HELLO! I spilled the oil in my brand new FloTec
Compressor oil will work. Home Depot, Lowes sells this oil, tool dept, where their compressors are located.
Posted on Aug 12, 2009
Testimonial: "THANK YOU for sharing your expertise with the cronically inexperienced!"
Bar oil in piston
HI
you may have broken or worn piston oil rings or damage piston on the inside diameter
Jan 11, 2018 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pump quit....gets hot!
THAT IS A CHEAP PUMP. JUST BUY A NEW ONE, THEY ARE HARD TO GET SEALED BACK UP AND JUST TO FIND IT WORKED FOR A WEEK.. VEGETABLE OIL .. IT MUST BE NON TOXIC OIL !! .. VOTE
May 24, 2010 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
When taking apart the pump I spilled the oil
I just went to the website, they don't say one word about the oil. They do have a toll free number. 1-800-365-6832,,, hope this helps.
Apr 27, 2010 | Flotec SimerOmni 3986 SS Sump Pump
How to change the oil pump
Before you change the pump, take it apart and look inside it could just be clogged with saw dust. If its anything like a chain saw it will only be clogged for this is a drip system I believe and not a pumped kind of system. Take a look before doing anything else. Good luck!
Oct 19, 2009 | Garden
Oil spilled during shipping
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Nov 03, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
