Question about Philips Magnavox 15MF400T 15 in. LCD Television
Menu problem I have a Philips split screen TV the menu will not come up by using the remote or by holding down the the up down volume button on the TV set. It will also, not display channel #s. I can scroll up and down but I do not know what channel I on. I'm assuming it is a programming issue I can correct, when I can open the menu. Any suggestions?
    Novelist:
    Champion:
  • 203 Answers
The first thing to try when you lose any feature or function is to unplug the set from it's power source for a minute to allow reset. The second thing to look closely at is to see if any button on the set or remote is engaged, meaning stuck. Sometimes a button gets lodged beneath it's surrounding framework and blocks certain commands from operating. If these two things fail to correct it, then it's time for a repairman, which, believe me, we're seeing alot of these lcd sets in for repair even only a year or two old. Most have power or screen issues, but yours sounds like there is a failure on the main p.c.b. This board controls audio/video processing and all information sent to the screen and speakers. Good luck with reset because defective replacement boards are becoming more and more numerous these days, Russmann.
Posted on Oct 28, 2008
I nedd to unlock my fpa on my RCA flat screen model 20V500T
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 26, 2012 | RCA Televison & Video
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
Seem like tv as lock on. rca tube flat screen
Hello
To unlock your RCA tv do the following. One amoung the method decrbed here will surely unlock your TV. I thinks that you have its orginal remote control with you.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Mar 04, 2011 | RCA TruFlat 27F520T 27" TV
My greentech tv was locked and dont know how to unlock it.so far only black screen appear with red key logo under the screen.
Hello
To unlock your RCA tv try the folloing. One amoung this method will surely unlock your TV. NB: Before trying each method be sure to switch OFF and switch ON your tv with its FRONT PANEL POWER CONTROL SWITCH.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Jan 16, 2011 | RCA TruFlat 27F520T 27" TV
Its a rca tv model # 20v500t serial # f075e5e61 i accidently set the fra lock or something like that in the menu screen and cant turn the tv back on and dont have the remote
Hello
  4. Hold down EJECT button on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 09, 2011 | RCA Televison & Video
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
How do I hack into channel blocks if I dont have the code? Its a Philips TV and it is fairly new.
If this is for GE or RCA:
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
If this is for different brand, let me know
Jul 09, 2009 | Televison & Video
Can't get closed caption off of television
If you have the original remote use the closed caption button to turn it off. Without the remote, hold down both volume buttons on the front of the tv to bring up the menu. Use the the channel and volume buttons to navigate in the menu. Select the center icon at the top of the screen. Go down to closed caption. Select OFF. Wait for menu to go away.
Mar 05, 2009 | Sansui DTV3200 32" TV
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Philips Magnavox 15MF400T 15 in. LCD Television Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
