Question about Bosch 14.4V Brute Tough Drill with Blue Core Battery Technology
Bosch cordless drill slipping in first gear
My 14.4v bosch is slipping in first gear only, any suggestions? thanks
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
comax
  • 154 Answers
SOURCE: I need to remove the chuck on my Bosch 33618 Brute
You must remove the inner chuck retaining bolt first, it is a torx screw and is left hand thread. once you have this screw out, get yourself a 1/2" allen key (the L kind). Chuck the short end in the chuck to grip it, use a mallet to hit on the long end (this will unthread the chuck). The spindle thread is regular Right hand thread. It may take a few good hits to knock it loose but it will come off.
Posted on Apr 13, 2009
  • 25 Answers
SOURCE: how long do I charge my 18 v PSR bosch cordless
about 180 mins or an hour and a half. if the light does not change, just make sure you put it properly on the charger base and time it for charging. Disconnect it after you are done. Usually, the light on the charger is just an indication that it is powered on.
Posted on Jul 28, 2009
brewerstool
  • 141 Answers
SOURCE: I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Posted on Sep 09, 2009
comax
  • 154 Answers
SOURCE: Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Posted on Jan 09, 2010
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Dough hook & beaters slipping
you can generally find a local repair shop that specializes in resturant/bakery equipment/small aplliance. they will have the parts you need as well.. good luck please rate this
Sep 03, 2008 | Bosch MUM4420UC Compact Series Stand Mixer
Transmission not shiftin
For car not changing gears it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
TRANSMISSION GEARS SLIPPING AND FLUID LEAKING ISSUES
Transmission gear assembly and transmission needs inspection. Also check the transmission fluid level. Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot this problem.
I suggest you to refer these links.
Click the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
These details will help.
Thanks.
Feb 15, 2013 | 2002 Jeep Grand Cherokee
Replaced 2 3 sol in trans goes forward in all gears
TRANSMISSION REPLACING AND TROUBLESHOOTING
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
Thanks.
Dec 07, 2012 | 2005 Pontiac Grand Am
1986 olds 88 trans slipping
Transmission gear assembly and transmission needs inspection.Also check the transmission fluid level.Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot these problem.
2000 Toyota Camry: Transmission slipping and Stuck up? http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear? http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping? http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping? http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem? http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating? http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
Ford Windstar transmission fluid leaking? http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
Thanks.
Nov 24, 2012 | Cars & Trucks
Trans starting slipping after modulator replaced
Thanks.
Nov 24, 2012 | 1986 Oldsmobile Delta 88
I,m having trouble getting the chuck off my 13618 bosch 18v hammerdrill. I have removed the screw then chucked a piece of hexed stock into it and reversed a half inch impact to it and it won't bre
Make sure it is in low gear on drill mode. try with just a bar in the socket and hit the end to shock it. This is sometimes better than a constant force.
Nov 21, 2012 | Bosch 13618 - 2G 18V Brute Tough Cordless...
2003 C3500 Manual Transmission
sounds like the syncro for fourth gear is warn out you need to take it apart to repair it
Jul 17, 2012 | Cars & Trucks
Beetle 2003 transmission
For ****** slips pout of second gear,i suggest you to click the link below and follow the troubleshooting procedure.http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
----------This will help.Thanks.
Feb 10, 2012 | 2003 Volkswagen New Beetle Convertible
Bosch 14.4V Brute Tough Drill with Blue Core Battery Technology Logo
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
