Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other laptops. Help it had been working for 6 months and suddenly its not
  • 25 more comments
  • sunkarisun Oct 28, 2008
    My WD 160GB external hard disk work fine till yesterday suddenly its not recognizing neither my desk top nor my laptop please help
  • Anonymous Nov 01, 2008
    My PC is not recognizing my WD Passport WD2500ME USB external drive.
    I used just A few days ago I used for the 1st time and it was recognizing the PC. I copied some files and pictures with out problem. Next day I connected the usb cable to my computer and the WD Passport drive and not recognized on 3 laptops. pls advise
    Redards,
    Tig
  • Anonymous Nov 06, 2008
    yup. disk doesn't show up in vista window explorer, but now is listed under disk mgmt as "unallocated".
  • ikiji Nov 07, 2008
    I have the 320Gb version and this is the second one ... all of a sudden within 3 months (not even been moved off the desk) it has simply stopped being recognised.
    Simply not good enough WD!
  • vinpat35 Nov 09, 2008
    My laptop not recognizing my WD passport 120 GB usb.
  • Anonymous Nov 28, 2008
    Bought a new computer with vista, moved my old external maxtor drive over and it worked fine for one month, now OS won't recognize the maxtor drive,
  • ante_tandara Dec 04, 2008
    I have the same problem, only that i have WD 250GB ext drive
  • Anonymous Dec 15, 2008
    yes
  • NevadaSam Dec 15, 2008
    WD Passport Essential 250 is not recognized on a PC running XP, but OK on others with same operating system. It is scary to think that after I have this drive full of important data that it may stop working on other PC's and I may never retrieve what is on it.
  • sapromo Dec 16, 2008
    Same problem with WD2500ME, it worked first off, copied some files, next shot nothing worked ever again... anybody found a solution?
  • Judie Kupillas
    Judie Kupillas Dec 20, 2008
    I was just using my WD Passport earlier today, and then I took it out and plugged it back in, and now my computer isn't recognizing it, but if I go to the control panel to view hard drives, it says it's there and that's it's working properly and that it has the latest driver installed. However, I'm not able to see it when I go to "My Computer." I'm getting very frustrated.
  • helenabraz Dec 25, 2008
    my mac wont load my digital passport. it has previously but now it wont and have some important data on there. how do i get it off?
  • Anonymous Dec 26, 2008
    wd500me - same issue. It worked the other day, now I can't get any PC to recognize it. At first it says it sees new hardware, acts like it is loaded, but can't see it anywhere. Any answers yet?
  • Anonymous Jan 01, 2009
    my hardrive is not recognized
  • tsouche Jan 02, 2009
    I have the same issue with a passport WD1600ME:
    - when I connect it for the first time to a PC (laptop or desktop), it works fine
    - but when I try to conenct it for a second time, then it is not detected/recognised. Typically Windows will not find the relevant drivers!!!
    This is plain scary: I can't use it to store important data...
  • Shelby Jones
    Shelby Jones Jan 04, 2009
    I had the very same problem with my 250GB Passport drive. I followed Lone_Rider23's suggestion below, and was able to get the drive to appear in XP once more. I did not have to format the drive, just had to change the drive letter.
    Hope this helps everyone else!
  • 007db Jan 13, 2009
    My PC is not recognizing my WD Passport 80GB USB external drive. It did fine as for the last few months then today it wont read.
  • Vijay J Jan 13, 2009
    My Harddrive is not detected on any computer...
  • Anonymous Jan 15, 2009
    Changed cable problem solved
  • nathan_rat Jan 29, 2009
    wd passport wont load when plugged in. The light turns on and you can heard it booting up but it does not open
  • mouhamed_att Feb 02, 2009
    my wd passport dosnt work and couldnt be seen on my mac and on another 2 computers
  • lobowolf623 Feb 02, 2009
    I bought a 500 GB My Passport Essential. It was working for about a
    week, but now when I plug it into the USB port on my MacBook, it isn't
    found and the USB light on the case starts flashing. I plugged it into an old desktop computer that isn't compatible with it, just to see if it would be found. It was, so it seems like an issue of bus power, but if that's the case, it shouldn't have worked for that first week. Please help.
  • originalkris Feb 03, 2009
    What can we do? It's so costly to buy another one... I got mine from Costco.... not from an electronic store, who do we go to?
  • lah269 Feb 05, 2009
    My Western Digital External Hard drive does not show up under My Computer on any of my 3 laptops and 2 desk tops. I tried using a new USB cord and it still does not work. The external harddrive's blue light remains lite once plugged in. I called the Western Digital Soultion Center and all they said send it back and we will send you a new one. Problem they won't and can't recovery any of my data (the 8,000 Europe photos). Please Help?
  • Billhowden Feb 10, 2009
    My Passport was working fine on my ABIT K9 XP 32 bit - for a while. Now it is not detected, even with rescan in disk management. I've run into lots of problems with drivers on the ABIT K9.
    It works on an old IBM running XP 32 bit.
  • sunkarisun May 11, 2010
    what was the solution? What we need to do?
  • Anonymous Mar 16, 2014
    I was using my WD for 9 months and was working fine, but now it has been a few days that I can't open it
I had the same issue. Its not a power issue because it shows up in device manager. Heres what I did.
Right-click on my computer and click Manage>Disk Management
Your drive should show up there. Right-click on it. If explore is not grayed out, assign a drive letter to it and you should then be bale to see it in my computer.
In my case explore was grayed out. I had to click on the option to format the drive. After re-formatting the passport explore was available. I then assigned a drive letter to it and I have access again.
I guess somehow using it on multiple computers srcewed up the file-system on it. I was using it between windows and linux.
This fixed my problem.
Posted on Jan 02, 2009
Another possibility is that the USB port does not provide sufficient current. I tried using a powered USB external hub, and the Passport drive was recognized - at least for now. See Western Digital dot com support where they say:
Cause:
There may not be enough power currently supplied to the machine's USB port. Some computer systems only supply 500mA of power through USB ports. The WD Passport hard drive requires a little over 1000mA of power at spin up.
Solution:
Try the Passport drive on another USB port or another computer. If the Passport drive is connected to a USB hub, try connecting it directly to the computer's USB port. If the drive is connected to a PCMCIA (PC Card) on a notebook computer, the drive may only function properly if you power it with the optional power adapter (Silver Passport) or a USB 2.0 Power Booster Cable (Black or Colored Passport). If you decide to use a third-party USB cable to connect the drive to the computer, the cable may not be able to transfer enough power to the drive (This includes USB "reel" cables and extension cables). Western Digital offers an optional power adaptor and an optional USB 2.0 Power Booster cable (the USB 2.0 Power Booster cable has two USB connectors that plug into the computer instead of one) through our Online Store.
Posted on Feb 12, 2009
What you need to do is go to right click on My Computer and then click Manage then click Disk Management. If you have your WD plugged in then you should see it as UNALLOCATED! Click on it to highlight and then right click and select NEW PARTITION. First of all you need to select EXTENDED DRIVE. once you set that up the border will turn green and say FREE SPACE. Once you have done this then right click again Select New Logical Drive and then give it a drive letter. After that, check the box that says quick format with a tick and then OK and in a few seconds you will see it in the large box above telling you its a healthy drive and the border will now turn light blue.
Goto to MY Computer and there you will see it now everytime you have your WD plugged in. Trust me, if you do all these direction right then you will have no problems.
Danwok
Posted on Aug 01, 2009
    Problem Solver:
  • 18 Answers
This problem is caused by a poor electrical connection. In some cases it may be related to the cable. Try a better quality cable. If not there, its probably where the hard drive plugs into the adapter card inside the case. Unplug your drive from the computer. Gently open the case and try not to break the tabs. Once you have it open unplug and plug the drive into the adapter card several times. Before closing the case again, connect the cable to see if your computer now recognizes your drive. If it doesn't, repeat the process, but make sure the cable is unplugged. Still no luck, try installing your drive in a new case. Good luck.
Posted on Jun 09, 2009
Lah269I have recovered data from a WD2500ME Passport USB Hard Disk. The Hard Disk was not recognized on any PC USB port. Simply removed the cover and removed hard disk from its casing. It was a Laptop SATA Hard disk. Connected the SATA Data cable from my PC and Sata Power Connector Cable. Started the PC and all the Data was accessible.
Seemed so complicated, then I thought of the weight differnce in my various USB cables. I have two, neither would work with a small cable. Pluged them in using the heaviest that came with a Sony camera that has a tdk something or other (fuse?) and they work great.
Posted on Jul 31, 2009
I don't know if this has bearing on your issue or not, but I found this thread since I had a similar problem with the 250G drive (WD2500ME). In my case, I just bought from New Egg, recertified, and when I connected it to my PC (running XP SP3) it just made a clicking noise and could not be recognized at all by the computer. BUT...I had it connected to a USB extension cable. When I connected it directly to a USB port, it recognized it, no clicking, installed and all of the pre-installed files were there! So make sure it is also not connected to an extension cable, as that apparently can weaken the USB power output!
Posted on May 10, 2010
I had a similar problem with my 250. Seems that when I networked the house systems, the default drive letter for the Passport was F: Since this was taken over by a networked drive,m I had to manually go in and allocate a drive letter for the Passport. Once I did this, everything showed up just fine, all my data is there. NO reformat needed, just change the drive letter.
Posted on Aug 08, 2009
Guys i had the same problem, this is due to a malfunction in the electronic board that powers the HD.
the only way to solve this is:
1- carefully break the plastic cover.
2- get out the HD and disconnect it from the board
3- buy a new casing for your HD (costs less that 10$) and reconnect it with it.
but unfortunately you will not be able to use western sync any more..
Posted on Dec 27, 2008
Had the same problem
ran the fat32 formatter off wd website
& it picked it straight up
Posted on Dec 02, 2009
  • dodgydave134 Dec 02, 2009
    try running the fat32 formatter off wd website
Before the problem faces on my external hard disk my dvd recognizes the hard disk but after i formated the external hard disk my dvd player does not recognize vidoe from external hard disk
Posted on Nov 05, 2010
I have the same issue with my 120gb passport.
Windows vista and xp says something about the usb running faster.
Vista recognizes it for a second and then it disappears.
Posted on Oct 29, 2008
Check if your USB connects correctly
Posted on Sep 01, 2009
4 Suggested Answers
zzptichka
  • 95 Answers
SOURCE: My PC is not recognizing my WD Passport 120GB USB external drive.
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Posted on Nov 30, 2008
These WD Passport external drives are junk. This happened to two of mine, switched to Maxtor.
Posted on Sep 01, 2008
my pc not recognizing my wd passport
Posted on Oct 05, 2008
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
Wont recognize usb anymore
if the external hard disk drive powers on, perhaps replacing the USB cable could help ?
i had WD extrenal, and it crapped out on me -- i had so much vital information that i lost . i finally discovered that the power modeul inside the housing that encases the drive was bad.. i coul not get the PC board replaced.
i hope you can resolve this with new USB cable.
have you tried another computer -- see if that PC recognises the WD external drive
let me know how it works out for you
Nov 03, 2010 | Western Digital WD Passport 250GB Portable...
My computer does not recognize my WD external drive
You've tried different USB cables; so, that cannot be the problem.
You've tried connecting to different computers; so, the problem is _not_ your computer.
What's left is "inside" the case:
* the USB-to-disk-drive adapter,
* the disk-drive.
Open the case, and remove the disk-drive, and connect it as a "slave" drive to some computer.
If it is detected, then the USB-to-disk-drive adapter that has failed.
If it not detected, then the disk-drive itself has failed.
FInd the serial-number on the Western Digital disk-drive, and enter it onto Western Digital's web-site, on the "check-warranty" page. If it's older than 3 years, the warranty probably has expired, unless you were "lucky" and got a 5-year warranty.
Western Digital has a "Customer Loyalty" program -- just buy a new Passport through their web-site, and cite the serial-number, and you'll get a significant discount on _their_ price (could be higher than your local retail computer-store) for a new (probably larger) Passport.
Apr 05, 2010 | Western Digital WD Passport 250GB Portable...
I have a 500gb WD My Passport external hard drive not connecting
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Mar 11, 2010 | Computers & Internet
My Passport Drive is no longer recognized by windows
Check to see if the drive is available in disk management, if so and it's got a blue bar at the bottom, try changing the drive letter. If not, try the following:
Normally with the passport drives, you receive a shorter USB cable (this is because the drive relies on power from the PC, which your normal length USB cannot offer sufficiently. If you are using a short cable, try connecting the drive to the back of your desktop PC, this generates more power than the ports on the front (the ports on the front are actually hubs). If none of these options work try it on another PC, using the steps above.
If you still have an issue, the drive has most likely failed and you will need to get data recovery done to retrieve your data. If you do so, contact samsung for warranty information, so that your warranty doesn't become void.
Jan 24, 2010 | Samsung Portable 120GB USB 2.0 External...
WD Passport appear as an unknown device
try it again, after going to wd dot com, and getting and installing a new set of drivers..
Oct 13, 2008 | Western Digital Computers & Internet
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
WD Passport not recognized anymore
Change your USB cable, I had same problem...changing the USB cable woked for me.
Jul 30, 2008 | Western Digital Passport WDXML800UE...
Jul 30, 2008 | Western Digital Caviar WD2500BB 250 GB...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
25,786 people viewed this question
Top Western Digital Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
joecoolvette
joecoolvette
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
