Question about Neff Ovens
Can I stack a neff oven on top of an Neff oven?
Neff compact microwave oven on top of a neff single oven without a shelf in between?
SOURCE: clock setting
Press the fourth button from the left (that looks like a tick) then turnthe knob to the right of it to set time as required
Posted on Mar 29, 2008
  • 1462 Answers
SOURCE: neff oven won't work after a power cut
you need to reset clock - get your book out and it gives instructions
Posted on Oct 08, 2008
  • 1462 Answers
SOURCE: Neff Oven Door Removed Incorrectly
you need to lock the hinges to get the door back.
it needs some strength
lay door flat on floor
force hinge against the spring until right back and put the locking arm over. i use my feet for this!
Posted on Nov 29, 2008
jyackle5
  • 8197 Answers
SOURCE: fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
SOURCE: Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Posted on Mar 08, 2009
What is rhe best temperature for cooking bread in the Neff 1451 oven?
On circotherm at around 210 in a preheated oven for first ten minute, then drop to 190 until finished. For a 2-2.5lb loaf that would be 10mins followed by 20-30mins depending how dark you want it. On the neff ovens down the left side the shelfs are numbered 4 at the top down to 1 at the bottom... you should use the shelf set on 1 or 3 (**NEVER IN POSITION 2**). Good Luck. Hope this helps.ps you can prove the bread in the oven by setting the selector to 'fan' but with no temp, the heat from the lamp will create enough heat (obviously the bulb/lamp need to be working!!)
Sep 14, 2011 | Neff B1451 Single circotherm plus Electric...
The door to my Neff oven is not closing so heat is escaping from the top - please help
You need new hinges use linkhttp://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?Maktx=b1644&eshoptype=A
click on the spares listing for your model (you will need the full Enr from the oven rating plate) and order the hinges (always replace as a pair). Hinges are on page 3 parts list in position 0319 and 0320 (these are not the parts numbers, you need to highlight these positions numbers on the breakdown from your specific model to get the correct part number (six digit part number) You may find that although the position number are different for the left and right the actual part numbers are the same. You can add the items to the basket and order directly from Neff.Hope this helps
Sep 02, 2011 | Neff B1644 Electric Single Oven
Hi, I have a single built in oven and it does not
Here is the web site for Neff. Surf this site and see if you can find you specific unit. Need model and sometime the serial numbers.
Good luck and hope this gets it done for you.
Oct 22, 2009 | Ovens
Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
Sep 10, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Apr 15, 2009 | Neff B1421 Electric Single Oven
Looking for installation instructions for a Neff B1691 oven
Neff have some downloadable installation instructions at www.neff.co.uk select neff owners, then customer service, this opens a new window which has instruction manuals as an option, select this and then enter an E number for the model ( i tried B1664) a similar single oven and this brought up a pdf file. At the end p67 it gives cable sizes and types and connection details which should give you what you need.
Please remember to rate this solution.
Dec 08, 2008 | Neff B1691 Single circotherm super...
Neff B1721 oven
good day,
hope this link below will solve your problem.
kitchen appliances
Oct 20, 2007 | Neff B1721 Compact single Circotherm oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
199 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
