My synergy v rt-u64cd-53 remote is not working properly. the cbl light keeps blinking or remains on then the channel jumps back to 6. when i remove the batteries everything works fine when i put them back in it works for a minute the starts blinking then going back to channel 6. is the remote faulty or can i correct myself...i just got it from the cable company about 3 weeks now
2 Suggested Answers
SOURCE: synergy V rt-u64cp remote to control Receiver volume
For those who want your audio device volume to work without changing modes here's how: hold cable and select until cable lights up - then press volume+ and then press audio. That's it.
Posted on Jan 28, 2010
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
Need to unlock the channel control on new Time Warner RC122 remotes to be able to change TV channel. Function is not even mentioned in their manual & TW on-line support was no help.
They are made for TW boxes only to control their TVs. I do not believe the option you request is available. use the original remote for the TVs to change the channels on the TVs.
Oct 13, 2013 | Televison & Video
I have a Hanspree TV and just got a Synergy V RT-U64CD remote, but the code printed for Hanspree, 768, does not work. Any Ideas?
Check other codes to Hanspree brand. If you wish to get more codes, check these links. Do not stick on brand name to remote control. Check for the code to Hanspree with any other remote control. The site mentioned above has three digits, four digits and five digit codes to different brand of popular remote controls. Check them with patience.
Feb 25, 2013 | Televison & Video
Uei mediacom remote cbl buton keeps blinking
Just take out the battery out from its battery compartment, and re-insert it. Try to program it after that.
Feb 10, 2013 | Televison & Video
I'm using a Time Warner remote as a universal for my TV but when I go to change channels, it just lights up the CBL button and doesn't change the channel. Can I program it to my TV or will it
Hi, you need to de-activate the "programming channel control lock" option. You can see instructions in the manual for the remote. They are as follows:
  1. On the remote control, press CBL once; It will blink once, Press and hold SETUP until the CBL key blinks twice.
  2. Enter 9 7 3. The CBL key will blink twice.
  3. Press CH- once. The CBL key will blink four times.
    Now the remote control will provide TV and VCR channel-control capabilities while in the TV mode.
for any other information with programming this remote:
Download the 1056B01 operating manual with codes for free.
Nov 30, 2012 | Televison & Video
Need codes for rcr 460 remote
1. Manually turn on the component
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
Note: If you press an invalid key
during the Manual Code Search,
the remote does not respond and
the LED indicator light does not
blink. If you do not press a valid
Manual Code Search key (TV,
VCR, DVD, SAT·CBL, ON·OFF,
GO BACK), the search times out
after two minutes. When the
search times out, the LED
indicator light blinks four times
and turns off. The last
programmed code under that
component key is retained.
2. Press and hold the component key
(TV, VCR, DVD, SAT·CBL) you
wish to program. The LED indicator
light turns on and remains on.
3. While holding the component
key down, press and hold the
ON·OFF key. The LED indicator
light turns off.
4. After holding down both keys
for three seconds, the LED
indicator light turns back on.
5. Release both keys. The LED
indicator light remains on.
Throughout the
programming of each key, be sure
to keep the remote pointed at the
IR sensor of the component you
are currently programming the
remote to control.
6. Press and release the ON·OFF key
repeatedly until your component
turns off. Each time you press the
ON·OFF key, the LED indicator
light blinks, and the next code in
the list is sent. This process
continues until all of the codes in
the Code Lists have been searched.
If your component turns off, you
have found the correct code. (If it
cycles through and the LED
and turns off, all codes have been
searched. The Manual Code Search
method is exited.)
Press Stop when TV turns off.
Mar 06, 2010 | RCA Universal Remote Control
I have a synergy V universal remote from
You have to hit mode, then select CBL it will then work
Jun 03, 2009 | Televison & Video
Synergy V rt-u64cp remote to control Receiver volume
Apr 06, 2009 | Televison & Video
Code For Scientific Atlanta Explorer 1840 Cable Box
Try this first:
1. Press and hold SELECT and CBL until all mode keys blink twice.
2. Press 9 7 7. All mode keys blink three times. Then, after a few seconds the CBL key
blinks twice.
This put's the remote back to default. If you need more help let me know.
Jul 09, 2008 | Sony RM-V401 Remote Control
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
