In toshiba studio 2500 error code CE40 - Office Equipment & Supplies
SOURCE: Error code in E studio 150
Hello! I did it and it worked perfectly.
I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
Posted on Feb 20, 2008
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
  • 4 Answers
SOURCE: Empty used toner not clearing
you have to go into service mode and reset counter.in your manuel
Posted on Jan 04, 2009
  • 653 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
  • 132 Answers
SOURCE: toshiba estudio 351c error code
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Posted on Apr 12, 2011
CAN YOU PLEASE GIVEN THE SOLUTION FOR ERROR IN ce40 code in estudio2050c
You must change black dev.unit lever clutch to fix CEB0
And you must change the belt that moves organic belt to fix CE40.
Aug 05, 2016 | Toshiba e-Studio 2050C Multifunction Color...
Ask me call for service
This model CE40 can cause by many factors
1. Make sure all the process unit is working ( especially main charger )
2. HVT board faulty
Sep 30, 2015 | Toshiba e-Studio 2050C Multifunction...
Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
Mar 19, 2012 | Office Equipment & Supplies
How do i fix fault code CE40 on the toshiba e studio 3500c
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 07, 2012 | Toshiba Office Equipment & Supplies
Call for service error in Toshiba studio 160
Code Description C01 Main motor drive error C04 PFP main motor drive error C06 LCF feed motor error (DP2000/2500 series) C13 Cassette 1 error C14 Cassette 2 error C15 Cassette 3 error C16 Cassette 4 error (DP2000/2500 series) C18 LCF tray error (DP2000/2500 series) C19 LCF feed motor abnormal (DP2000/2500 series) C21 Carriage initialization error C25 Scanner unit watch dog error C26 Exposure lamp disconnection or peak detection error C38 Replaced process unit error C41 Abnormal thermistor or heater disconnection at power ON C43 Warming up mode after disconnection judgment, or abnormal thermistor after ready C44 Warming up mode after disconnection judgment, or heater abnormal after ready C45 Thermistor disconnection at the end part of heater C56 Communication error between PFC and main unit C57 Communication error between main unit and IPC (DP2000/2500 series)
May 22, 2011 | Toshiba E-Studio 160 All-In-One Laser...
Can you please giv a soluton for this issue: error code CE 40 toshiba e studio 3520
CE40: Image quality control test pattern abnormality: The test pattern
is not formed normally. If you switch off at the right hand side of the machine, wait
10 secs then back on again, It should clear. I think it is caused by condensation.
It can also be transfer belt failure, or paper rubbing against the transfer belt. It could be
because the Developer Unit failed to Pass the Close Looping Check by the machine
every time it boots.... check for fault from 08-824 if the value of any color is " 1 "
means abnormal occur.... check for foreign matters on the dev tank...the
simplest way is clean all 3 tanks...then reset it back to "0" then do a 05-200 and
05-396-4-Fax-1624-Set
95% solved the case
Jan 15, 2011 | Toshiba E-Studio 3511 Color Copier
BOTA ERROR CE40
1.Replace the image quality sensor
2.Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid). MEANING Shutdown the machine,press 0+8,while starting the machine, enter 556 then enter 1,confirm it,then press 557 then 1,confirm it.
Below are further instructions in the same way
3.Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
4.Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to
576)"
That is it
Jan 04, 2011 | Toshiba E-studio 281c Copier
492 people viewed this question
k24674
jasbo
jasbo
