Question about Ariston Technologies AWD 121
ARISTON AWD 121 NA doesnt tumbledry clothes
Hi.
This combined washer/dryer only washes the clothes, but when the dryer function is supposed to begin, it just stops and starts making clicking noises-like its trying to move on to the next program, but isnt able to. I just have to stop it and take out the clothes which are then VERY wet.
Hope you can help.
Thank you.
  • Anonymous Jan 15, 2009
    I have had the same problem. The repairman has changed the thermostat in the unit, which has allowed the unit to dry clothes, but it has broken 3 times. I want to be rid of this device.
  • 209 Answers
SOURCE: aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Posted on Sep 14, 2007
jaylex
  • 417 Answers
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Posted on Feb 05, 2008
  • 251 Answers
SOURCE: Ariston AWD 121 wont work
make sure the water supply is turned on , a small red and blue tap usually under the sink
Posted on Nov 11, 2009
  • 1417 Answers
SOURCE: I have the error code 5 on the Ariston washer
hello,
what this mean is that the error code 5 indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). in your drying machine.
thank you.
Posted on Jun 07, 2010
Daniel S
  • 4323 Answers
SOURCE: The drying cycle on my
Hi
The issue is either with the thermal fuse of the unit that is bad or the motor that has gone bad. To check what is causing this, first check the fuse which is located inside the rear panel to the exhaust duct and try to jump start the thermal fuse or test its continuity with a voltmeter, no continuity means bad fuse. If the fuse is okay then replace the motor as that part usually makes a hum sound when it is unable to run. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 23, 2011
Lavadora aqualtis error11
F11: Pump Feedback Missing
Overhaul CN1
Overhaul CNF
Overhaul Pump Connector
Overhaul Pressure Switch Connector
Control Pump Windings
Replace Pump
Replace Card
Dado
Jun 25, 2014 | Ariston Technologies AWD 129 NA Washer/...
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
Lavadora secadora ariston aqualtis aqm8d error f13
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
Dado
Apr 08, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston h20 errors
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Jan 14, 2014 | Ariston Technologies AWD 129 NA Washer/...
Awd121na heating element, where to buy
you can usually go online to the manufacturer website and the can tell you where you can either order the part or pick up the part at a near by store. when u are at the website go to support and call them. if they have good customer service. your problem will be fixed in no time
Apr 02, 2013 | Ariston AWD121NA Washer/Dryer Combination,...
Rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
May 14, 2009 | Ariston Technologies AWD 129 NA Washer/...
Ariston Washer/Dryer NOT heating up during drying
hi mayday malone. i have the same machine and the same dryer not heating up problem. how did you fix yours? thanks toddelsliger@yahoo.com
Nov 24, 2007 | Ariston Technologies AWD 121
Ariston Technologies AWD 121 Logo
113 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
