How to set up video funai
Cannot setup
Hi: I just got a Orion vcr, but I don't have the manual to set it up! is there one I can get! if
Please reply,Thank You Kindly. gelonel@yahoo.com
Posted on Oct 31, 2008
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
Tip
Not just Emerson, all products made by FUNAI Corp., which also includes Sylvania...
Apparently Emerson has acknowledged that a large number of these have defective clocks (it locks up and wont advance). However, they won't take responsibility and repair them (it's now an "old model"), and as of yet I have found no decent info on the repair.
on Jan 30, 2008 | Emerson EWH100F
How do I switch from catv to antenna on model mwc13d6
First make sure that the TV/DVD player is on TV by pressing the Channel Up. (The channel up/down will rotate through AUX and any programmed channels.) You'll need the original remote or an universal remote that matches the Set-up function. Then press Set-up on the remote; it's to the left of Mute above Play.
Use the Up/Down arrows to navigate to Channel Setup. Press Enter to access the Channel Setup menu. Use the Up and Down arrows to select Auto Ch Programming and press Enter. Wait for the TV to scan all available channels. Afterwards, you can go back to the Channel Setup menu and choose Add/Delete channels. Press Set-Up again to exit the On-screen menu system.
Unless you have a set-top Digital-to-Analog converter attached to the TV, you will only get one of the few remaining low power analog stations, if you are close to the transmitter. This set only has an NTSC tuner. Most set-top boxes can be attached to the Antenna input and be set to Channel 3 or 4 or connected to the Aux input.
The Magnavox MWC13D6 was manufactured by Funai and the manual is available here: http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is MWC13D6 is http://www.funai-corp.com/support/om/MWC13D6.pdf .
I hope this helps.
Mar 24, 2015 | Televison & Video
Message says see first page of manual
Do you have a coaxial cable attached to the antenna in on the TV? The TV has an ATSC (digital OTA) tuner and a NTSC (analog OTA or CATV) tuner. The initial setup wants the incoming antenna in signal to be present (this is the only message on the front of the TV manual).
This TV was built by Funai and the manual is available from Funai's support page: http://www.funai-corp.com/support/manuals.aspx . Since Funai makes TVs for a number of brands, the best option is to search for the model number (leave off the brand name) in their search box. The direct link to the IWT3206 manual is http://www.funai-corp.com/6pdf/om/IWT3206.pdf .
I hope this helps.
Sep 17, 2011 | iLO IWT3206 TV
I have a digital cable box with comcast but cannot get it programmed with my tv using all the sylvania codes i have
Look in the setup manual for the Comcast remote and either try the scan feature for programming or try the Funai codes as most likely the set is made by Funai.
Nov 11, 2009 | Televison & Video
I need to see a diagram of the back of the tv to help hook up cab
Go here for the manual:
http://www.funai-corp.com/6pdf/om/CR202TT9.pdf
Back panel diagram is on page 7. Setup selections are menu driven. See page 10 for Initial Setup. Channel scan (after setting input to "Cable") should do most of the work for you.
Jun 30, 2009 | Funai CR202TT9 20" TV
Funai T3B-N8182DB
connect a freeview box to av2(scart in)
press input select to av2
Sep 15, 2008 | Funai PY90VG DVD Player/VCR
Funai fdp-100 photo printer drivers
I have a Funai Digital photo printer FDP-100 but no setup disc /driver can you help
Jul 25, 2008 | Funai PY90DG DVD Recorder
My sylvania model 6620lf4 lcd color tv suddenly has an inverse picture, how can I fix this??
THIS T.V. IS ACTUALLY MADE BY FUNAI. IT SEEM THAT ALL OF THE NEW SYLVANIA'S ARE FUNAI'S. WHEN I HAVE TO FIX ONE I HAVE TO CALL FUNAI FOR PARTS. MOST OF THE TIME THEY ARE NOT AVAILABLE. IF IT MENU IS GOOD AND THE PICTURE IS BAD THEN IT HAS A VIDEO PROBLEM AND PROBABLY NEEDS A MAIN (VIDEO) BOARD. MOST OF THE TIME THE BOARDS EXCEED THE PRICE OF THE T.V. MY PART DISTRIBUTOR DOES NOT CARRY FUNAI. SORRY I CANT GET YOU THE PART NUMBER OR PRICE. TRY CALLING FUNAI FOR THE PRIVE ON THE BOARD. IT IS EASY TO PUT IN.
DON.
Jun 03, 2008 | Televison & Video
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
