Question about Brother HL 2270DW Laser Printer
Brother HL-2270DW printer printing 3 vertical lines
Prints 3 vertical lines (each are about 1/4" in size) down center of page.
hvpatel
  • 152 Answers
SOURCE: Dark line down printed page
problem in your fuser assy call to hardware service provider
Posted on Feb 29, 2008
  • 116 Answers
SOURCE: Black line down middle of page
Clean the inside of the printer with a soft rag, be gentle and get as much toner up as you can, also your toner carttridge may be empty or the crum may be bad, start with a fresh toner carttridge and clean the printer out where the cartridge sits.
Posted on Dec 13, 2008
leroyal
  • 2120 Answers
SOURCE: brother printer that prints a black line down center
probably a bad drum cleaning blade, It's part of the drum unit
Posted on Feb 03, 2009
  • 298 Answers
SOURCE: printing problem
Vertical line is probably scratch in Toner/image drum or one of the erase LED bar lamps is out. Start by replacing the Drum and see if it is better. LED erase lamp assy is more expensive so I hope for you that it is the drum.
Saw this scratched tomer drum on a ton of HP I serviced while in Europe
Cheers!
Posted on Mar 26, 2009
ryeisenman
  • 9 Answers
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Posted on Nov 21, 2009
Printer brother HL 2275DW print blank page
Re-installing the printer driver after resetting the printer to factory default should work for you..
Jun 20, 2014 | Brother HL 2270DW Laser Printer
Printer prints random characters
Hi Erica,Try to shut it off, but if you can't, unplug it. Then try canceling it and plug it back in.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Feb 06, 2014 | Brother Office Equipment & Supplies
False 'Cannot Print' Warning on Brother HL2270 DW
Hi, as one comment mentioned, you should try configuring the sleep timer, I had the same problem and that did the trick. Those Brother printers can be painful to deal with sometimes :) Btw, if you need the service manual, you can find one here - Brother HL-2270DW manual
Jan 25, 2013 | Brother HL2270DW HL-2270DW Compact...
My HL 2270DW won't stop printing goobldegook. One or so lines on each page, and the printer job does not show in the cue so it can not be cancelled. I can not print any jobs because of this malfun
Has it worked before? Many of these newer printers can print what are called Postscript documents, and you may have a Postscript driver instaled instead of the regular driver, or both and have selected the wrong driver when sending the job ORyou have an internal circuit board that'sgone bad
Jan 07, 2013 | Brother HL 2270DW Laser Printer
I just bought a Brother HL-2270DW Laser Printer and it says it can do two sided printing. How do I do that? I don't have a manual - it just came with a Set up Guide. Thank-you.
First you can download the manual here : http://www.iusermanual.com/printer/brother-hl-2270dw-printer-manual.htm
Usually you need to enable DUPLEX option in the printer's managing software...
Jun 18, 2011 | Brother HL 2270DW Laser Printer
When I hook up my printer (ether USB or wireless) the printer immediately prints one blank page and jams halfway through the 2nd. There is nothing on either page, and there are no print jobs in the queue...
You will need to either clean the pickup rollers , or order a service kit to replace them, if not the rollers then it will be a blockage along the paper path, try pushing some nice thick paper along the print path from various positions to see if you can clear it.
Jun 04, 2011 | Brother HL 2270DW Laser Printer
Prints only blank pages
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 06, 2010 | Brother HL-2040 Laser Printer
Brother HL 2270DW Laser Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
