Question about GE Spacemaker JVM1640SJ Microwave Oven
Replacing door latch pawl
GE microvave #JVM1542BF001
I am replacing the broken latch pawl on my microwave door - I have removed the choke cover and access to the latch pawl still seems to be restricted. Is this as far as I need to go or is additional disassembly of the door necessary? If so what is the next step and how do I go about it without causing damage to the door?
Thanks
Ed
How do I replace door latches on a spacermaker XL microwave oven? thanks
Posted on Nov 02, 2008
GE Countertop Microwave Oven Door is stuck closed
Remove the cover. You should be able to access the two latches and release them. Once open you will have to take the door apart and repair the latch
May 05, 2014 | GE Profile Spacemaker Over-the-Range...
Need to replace door handle
1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it. 4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame. 6. Starting at the top right corner, pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later. 7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE: When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components. 8. To remove the door switch actuators from the choke, remove the screw from each actuator. REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
Read more: http://www.appliancepartspros.com/whirlpool-microwave-door-handle-w10246505-ap4418092.html#qa1#ixzz2qpA2P5CA
Jan 17, 2014 | Whirlpool MH3184XP Microwave Oven
I got the screws off for the door handle on the ACO1860AS Microwave but the handle will still not come off. Is there another mechanisme or hidden screw that needs to come out?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
From the service manual:
Door Disassembly
1. Disconnect power to oven and remove oven door,
(see "Door Removal" procedure).
2. Pry away choke cover, by placing a tool in the upper
right corner of the door and gently prying outward on
the choke cover. Continue to work around the door
casing until choke cover is completely loose.
3. Slide latch assembly upward and to the left to
release plastic tabs from door frame. Once latch
assembly is loose the spring may be disconnected
4. Remove screws securing door handle and door
frame to door panel.
5. Remove door frame by releasing tabs around entire
door panel.
Remove door handle by placing a hand on door panel
next to the top of the door handle. Twist door panel
towards the inside of door and pulling on the top
portion of the door handle in a quick jerking motion.
NOTE: When replacing door handle, the bottom portion
of the door handle must be inserted first.
You can find handy exploded views and order parts by model number here.
Apr 18, 2010 | Amana ACO1860 Microwave Oven
Ge jvm1542bf001 has rust discoloration on glass part of door. Took door off, removed handle. Is there a way to access the inner surface to rid grid of rust?
It would appear that no one knows how tofix this problem. I have the same problem and the only sugestions I get is to replace the door.
Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Problem: How can I replace the door handle on a GE, JVM1490WD 003 microwave oven? The door handle has broken off leaving in place the parts that attach to the door and I see no way way of removing THE...
ok start over
you need to be looking at the inside of the door
the frame around the glass the choke
will pop off,,
take a small flat head place it between the choke and the frame down by the hinge. pry ever so carefully it will pop out slide the screwdriver around the edge until the whole choke is dislodged
once the choke is off
you will see the two screws for the handle
you may need to lift the latch mechinism to get to the bottom one
once your done you can simply push the choke back it place you will here it snap
be careful the choke is very brittle
and will break if bent
Oct 10, 2009 | GE JVM1490 Convection/Microwave Oven
How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Sep 11, 2009 | Sharp R-1610 Microwave Oven
Broken Bottom Latch Pawl GE Advantium 120 Microwave
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 24, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave starts after plug-in cannot be stopped by control panel
This seems like a problem with with the door latch circuitry HW. If the unit is still in warranty, call GE customer care. If not, your neighbor will need to buy a new oven. Service on microwave ovens is not cost effective because the replacements are so reasonable and have so many new features.
I have a lot of experience with these units. If the door latch circuitry is in question you may be exposed to dangerous microwave energy. Hope this helps...
Ray
Nov 20, 2008 | GE Microwave Ovens
Broken door handle
bogus...use a Torx driver to remove the door screws...careful of the glass. Replace the handle and reassemble. You may want to take digital pictures along the way. Parts available from ge or other online parts guys.
Dec 18, 2007 | GE Advantium SCA1000H Convection /...
The door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
573 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
