Question about GE 46GW947 46" Rear Projection Television
Sider webs I have spider webs behind my screen. Does anybody know how to remove the screen on this model so I can get rid of them?
Here's my suggestion: I have a 55" Philips HDTV and I live in an area known for excessive dust and more than a fair share of spiders. I checked online and found that there are usually 1-4 access panels that can be removed for cleaning, repair, etc. Here are my steps: 1. Remove the upper most panel (usually a trapezoid-shaped plastic "box"). There are anywhere from 1-4 "hangers" that, once all the screws are removed, will hold the panel in place while you are unscrewing the last few screws. 2. Remove the panel and clean with a lint-free cloth the entire inside of the panel. This is an area where a lot of dust and spider webs can be found. 3. Grab your vacuum cleaner and carefully clean away all the spider webs. Making sure you don't bump into the inside of the projector screen! 4. Spray a small amount of dust cleaner or window cleaner on the lint-free cloth and run the entire length of the TV. Clean all surfaces this way except the reflector (mirror). It is best to clean the mirror with compressed air (get it anywhere - usually in the computer section). 5. Using a flashlight or bare lightbulb, thoroughly inspect all surfaces for dust and spiderwebs. And, of course, clean anything missed the first time around. 6. Using a clean lint-free cloth (I find cotton underwear from Wal-Mart works the best), spray a very small amount of window cleaner (streak-free Windex, etc.) on the cloth and rub the cloth together until almost dry. Then, simply wipe all three lenses clean. 7. Replace the back panel and pay close attention to the alignment of the holes to ensure the screw goes back in the same way it came (if not, the panel could ultimately lose the seal and allow for more dust). 8. Allow for several minutes drying time before turning the set back on. Hints: 1. Clean the speaker area, too. 2. Repeat the process at least each 30 - 45 days to ensure optimal performance. 3. Use a small computer fan to circulate air behind the set if the area gathers excessive dust. They're quiet and can be purchased (almost anywhere - Radio Shack, Wal-Mart, etc.)with switches that are easily accessible.
Posted on Jul 24, 2007
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Spider webs behind screen
Pardon me but do you mean the screen has spider web looking patterns all over it? Or are you saying that spiders have crawled into your set and spun webs to catch flies?
If you have a spider web pattern problem then something has impacted your television screen and it is broken. You can check and see if your homeowner's insurance covers this, contact a service provider to see if they want to buy the television for its parts, and contact Mitsubishi to see if they offer a discount or pro rated rate on a new or refurbished television for when things like this happen.
If the problem is that you have spiders in your television I do not recommend vacuuming it out. I have seen people's televisions go out after they attempt to remove dust and webs that way. In this instance I also recommend contacting a servicer and the manufacturer.
Jan 28, 2011 | Toshiba 57HX83 57" Rear Projection...
I have a spider web behind the screen, how do i
sometimes on sony TV's on the sides you will have a door, that you can open with a screwdriver. if yours have it you might be able to dlean all that web from both sides, if not its a little bit more complex.
Jun 25, 2009 | Sony KP-53HS30 53" Rear Projection...
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Looks like dust behind front glass on phillips 46pp8621
The only way to remove the dust and or spider webs from that area is to remove the front bezel assembly and separate the protection screen, it's better to leave a svc. co. do this because the two screens behind that are very expensive. Hope this helps..
Feb 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Spider web behind front of screen
Take the front speaker grill, and ther will be a few screws on the bottom of the screen. Remove those and lift the screen up and out.
Feb 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Spiderwebs under Screen, how do i clean it ?
Yes, I have seen this many times. Usually the best way is to remove the upper back cover and clean out the spider webs with a soft, dry cloth, but be careful because the mirror is mounted to the inside of the cover.
Jun 24, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Clean inside of the screen? Spider webs?
You should get the service manual so you dont take apart something you shouldnt
Aug 24, 2006 | Panasonic PT-61HX40 61" Rear Projection...
GE 46GW947 46" Rear Projection Television Logo
169 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
