Our HP 3050 will not receive a fax from a HP1050
We can get all faxes fine except from a HP 1050 machine. The fax number rings then we get a communication error.
    Genius:
  • 1,550 Answers
You need to check the settings ?
Are you getting any error codes ?
Posted on Oct 28, 2008
  • SAM ANDERSON Oct 28, 2008
    Reconfigure the local fax machine to use different configuration
    settings, toggle the ECM state and/or select a slower reception speed.
    To Disable ECM, perform the following steps:
    • Press the <
      or >
      button until the front display reads "Fax Setup".
    • Press the ENTER/MENU button.
    • Press the <
      or >
      button until the front display reads "All Faxes".
    • Press the <
      or >
      button until the front display reads "Error Correction".
    • Press the < or > button until the font display reads "Off" and
      then press the ENTER/MENU button to save the setting. (Off disables ECM
      and On enables ECM).
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Fax machine not copying?
If you have an HP 1040 or 1050 fax machine be sure tot checkout this article about the recall HP did on this machine due to a potential fire hazard. You need to contact HP before you have problems with the unit.
http://www.ccl-la.com/blog/index.php/recall-on-hp-1040-and-1050-fax-machines/
BuddyMc
Mar 01, 2012 | HP 1040 Plain Paper Inkjet Fax
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
I cannot receive faxes. I have a voicemail set up on my phone that is in use. I would like to use the 1050 as a phone and a fax machine only. I will settle if I could only use it as a fax machine. I have...
If you have a voicemail set on the same line then you may only be able to use either the fax or the voice mail if you want to the fax then change the rings to answer on the fax to 2 (setup button->basic fax settings->rings to answer->press ok on 2) keep the mode to auto mode. However if you want to use both the voicemail and the fax on the same line you might have to get a DRP (Distinctive Ring Pattern) from you telephone company.
Jun 10, 2010 | HP 1050 Plain Paper Inkjet Fax
Change amount of times fax rings before receiving fax hp laserjet 3050
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf Page 123
To set the number of rings-to-answer To set or change the number of rings-to-answer, use the following steps: 1. On the all-in-one control panel, press Menu. 2. Use the < or the > button to select Fax setup, and then press . 3. Use the < or the > button to select Fax Recv. setup, and then press . 4. Use the < or the > button to select Rings to answer, and then press . 5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press .
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | HP LaserJet 3050 All-In-One Printer
I cant send faxes over voip with the hp laserjet 3050 fax machine....really at a loss of what to do keep getting comm errors.....receiving faxes just fine
I found a blog on the Ooma site that said this can be fixed by prefixing your fax send number with 99. There were several comments from people who tired this fix and it worked for them!
Nov 23, 2009 | HP LaserJet 3050 All-In-One Printer
Unable to receive fax from HP LaserJet 3050
Please make sure the machine is set for auto-receive in machine set up and make sure the phone cord is plugged into the line jack on the machine. If this machine is not on a dedicated phone line the machine (rings) should be set to pick up before the answering machine does.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
Not receiving faxes
You must have an analog phone line to fax successfully.
Jul 09, 2009 | HP LaserJet 3050 Printer
Fax receiving problem in 3050
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Dec 28, 2007 | HP LaserJet 3050 All-In-One Printer
56 people viewed this question
jasbo
jasbo
