Technika TV pink and green lines on screen - Televison & Video
IFIXALL
  • 868 Answers
SOURCE: red, green and pink on the TV
Possibly a magnet was is the reason.Can you Degauss from the menu>>?
Posted on Jun 03, 2008
  • 304 Answers
SOURCE: Pink and green lines and double picture.
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
Posted on Jul 17, 2009
  • 20 Answers
SOURCE: Pink and green lines are starting to appear that
Try unplugging everything other than the TV and the cable (or whatever service you have) and while your tv is on, plug everything back in separately. I did this and found that while my ps3 was plugged in, I caught interference on my cable TV. Also, make sure that any cords behind the TV aren't all jumbled. Sometimes having a bunch of twisted up wires can cause interference.
Posted on Feb 11, 2010
  • 346 Answers
SOURCE: I have pink and green horizontal lines on daewoo
the vertical circuit does not work
Posted on Jun 28, 2010
  • 1156 Answers
SOURCE: a green and pink line roll up the screen and we
All plasma an LCD Television have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken .
Good luck in solving the problem.....
Posted on May 06, 2011
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Technika tv screen goes pink when plugged into laptop movie
try reseting the laptop when the tv is plugged
Apr 24, 2014 | Televison & Video
Technika 19-228
It sounds like you are using a component video cable (red/green/blue) and either the red or blue cable is loose or broken. Most likely the blue. Check both at DVD and TV ends.
Dec 30, 2013 | Televison & Video
Tv screen shows green/pink
Ur video board that connected to the CRT long neck(tv tube).Have burn,capacitors?Or cold solder socket pins connected to the crt tube,must resolder,might solved prob.
Oct 14, 2009 | Televison & Video
Pink and green lines and double picture on Samsung big screen tv.
Jul 08, 2009 | Samsung LN40A650A LCD TV
Pink and green lines running through my hitachi tv?
i have a hitachi projection tv and im getting blue lines behind the lettering and on different spots of the screen can anyone help
May 12, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Left side of screen going yellow and pink with leters in double
The convergence modules have gone bad Along with the new parts kit are fuses, diodes, and resistors that usually fry when these modules go bad. Depending on the model, there will be two and sometimes 3 of these modules that have to be replaced. Each module has 50 pins each that have to be soldered, so unless you have experience with complicated TV repairs, the cost to do that repair may be as much as a flat screen TV of the same screen size as yours.
May 12, 2017 | Mitsubishi WS-65711 65" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
361 people viewed this question
Top Televison & Video Experts
Electro Med Services...
