Question about Ovens
Whirlpool akz446 oven not heating yet fan working
SOURCE: whirlpool oven does not work
http://forum.doityourself.com/showthread.php?t=241972
I have the same problem and found the information at the above site......
Posted on Sep 05, 2008
barkencoa
  • 3463 Answers
SOURCE: oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Posted on Dec 18, 2008
heavyice
  • 374 Answers
SOURCE: I have a whirlpool oven model no. G2P61/01SR/WH. It does not heat
The problem lies in your magnatone used for heating up the oven.You need a replacement for that.
Posted on Jun 04, 2009
  • 25 Answers
SOURCE: my whirlpool fan assisted oven is not heating
Sounds like you need a new fan element. You'll need to quote your model to ensure you get the correct element. A lot of Whirlpools can be done from the inside so the oven stays in the housing. Don't forget to power off first though! :)
Posted on Jun 25, 2009
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
Hi can you please tell me where i can obtain a user manual for a whirlpool electric cooker akz446/IX
whilpool has a very good sight , and you can download for FREE the manual you nhttp://www.whirlpool.com/eed
Jul 27, 2011 | Whirlpool Ovens
Hi, It looks as if my heating element on my AKZ446/IX oven has gone, as the fan, oven and grill work fine but no heat come out from the oven. I've seen on the online videos how to change the heating...
NEmmake sure you removed the correct item first
replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
Jan 26, 2011 | Whirlpool AKZ159IX Oven
Not heating
If it is a fan assisted electric oven, and the fan is working o/k, then it is probably the oven element that is faulty.
This is located behind a remoiveable cover at the reart of the inner oven compartment.
May 21, 2010 | Whirlpool RBS245PDS Electric Single Oven
Oven not heating up
If it is a fan assisisted oven, and the fan is working o/k, then it is pronably a faulty fan oven element that is faulty.
Mar 29, 2010 | Whirlpool RBS275PD Electric Single Oven
Ihave a whirlpool oven model gbs277pdo1 that will
this could be the timer is set to auto this data sheet might help For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Whirlpool GBS277PD Electric Single Oven
Oven not heating up
If it is a fan assisted oven and the fan is still wiorking o/k, then you need to replace the oven element, located behind the rear panel in oven.
Please rate my solution.
Thanks.
Nov 09, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool 6MFOS oven not heating
Do you still have this oven? I broke my glass door and need a replacement. thanks
Oct 19, 2009 | Whirlpool Ovens
Jun 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Apr 12, 2009 | Ovens
Ovens Logo
59 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
