Question about Texas Instruments TI-Nspire Graphic Calculator
Ti n-spire in infinite loop
When I turned on the ti-nspire in ti-84 mode, it goes into an infinite loop. Is there a force quit?
SOURCE: TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Posted on Nov 25, 2009
  • 7993 Answers
SOURCE: ti 84 nspire,replaced batteries and now it says
Hi
A. Download the TINspire OS from education.ti.com
Use the Ti-Nspire computer link to reload the OS onto the calculator.
  1. Remove the Ti84 keyboard and insert the Ti-Nspire keyboard.
  2. Make sure the battery are good.
  3. Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable
  4. Run the Ti-Nspire computer link software.
  5. The select device dialog should appear, and detect the device.
  6. With the mouse cursor, select the OS, drag it and drop it on the main window (file browser window) of the TI-Nspire computer link software.
  7. Alternatively, click the menu Tools and select Install OS. A Select file window opens.Use the browse button to point to the OS and click Open/OK
B Installing from another Ti-Nspire ( not a TI-Nspire CAS) if availabe)
  1. Connect the two devices using the USB Mini A to Mini B cable
  2. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
  3. Both units must be turned ON
  4. On the sending unit, access the document chooser by pressing [Home](the house icon).
  5. Once in the document chooser, press [Menu] and choose 9:Send OS…
Hope it helps.
Thank you for rating the solution.
Posted on Dec 11, 2009
  • 7993 Answers
SOURCE: TI-Nspire 84 Plus keypad problem
Remove the TI84 Keyboard, insert the TI-Nspire keyboard and try to reset the calculator with a starightened paper clip.Calculator has a reset button on the back.
Posted on Feb 01, 2010
  • 24 Answers
SOURCE: I have issues turning on my TI-Nspire using TI-84 Plus SE keypad
i would say use the normal key pad or send it in to T.I to fix.
Posted on Mar 12, 2010
  • 51 Answers
SOURCE: I am going to be getting a tinspire and I was
I am going to assume that you are buying the non-cas version as the Cas or computer algebra version of the nspire doesn't support the ti-nspire mode.
The tinspire will come with two key-boards. One will be the nspire keyboard, the other the ti-84 board. To switch between them there is a small toggle on the back of the calculator. Push the switch and the keyboard will pop out. Put the ti-84 keyboard in and then press the on button!
Cheers
Sine Wave
Posted on Apr 09, 2011
Testimonial: "Thanks for the help!"
How do i install the ti-84 operating system to the ti nspire
You do not. The TINspire with TI-84 keyboard works as a TI-84 Silver edition. Its OS is update when the TINspire OS is updated. The Ti 84 OS's you find on the TI website are not for the TINspire with TI84 keyboard.
May 12, 2014 | Texas Instruments TI-Nspire Graphic...
I am own a Ti-nspire and trying to download the latest Ti-84 silver plus os however when it begins to transfer to my calculator it says transfer error what can i do to fix this?
The standalone version of the OS for the TI84Plus/TI84Plus SE are not for TI-Nspire with TI84 keyboard. The 94 Plus part of the TI-Nspire is updated when you update the OS of the TI-Nspire. The version numbers are different.
To update you TI84 portion of the TI-Nspire, update the OS for the TI-Nspire. Thy are now at Version 3.2.3.1233
Sep 26, 2013 | Texas Instruments TI-Nspire Graphic...
Os transferring error
Sep 26, 2013 | Texas Instruments TI-84 Plus Silver...
Ti-84plus keypad for ti-nspire w/touchpad while in a+bi mode i enter the the problem (2-5i) / (1-6i). once i press "ENTER" i get a decimal. i want the answer in frac form, but when i press...
Here is screen capture of the calculation, performed on TINspire with TI 84 plus keyboard.To type in the imaginary unit use key sequence [2nd][dot], do not use [ALPHA][X^2] for the letter I.
k24674_90.jpg,
Jun 09, 2011 | Texas Instruments TI-84 Plus Calculator
I am going to be getting a tinspire and I was wondering how you switch from ti-nspire mode to the ti-84 mode?
Cheers
Sine Wave
Apr 09, 2011 | Texas Instruments TI-Nspire Graphic...
Mar 12, 2010 | Texas Instruments TI-Nspire Graphic...
Jan 23, 2010 | Texas Instruments TI-Nspire Graphic...
Ti 84 nspire,replaced batteries and now it says "operating system not found,install OS" Of course my son has a finals exam tomorrow..help!!
Hi
Hope it helps.
Dec 11, 2009 | Texas Instruments TI-84 Plus Calculator
Nov 23, 2009 | Texas Instruments TI-Nspire Graphic...
TI 83 TI 84 and TI Nspire
Yes, the Ti nspire not only functions as a ti83 but, also operate w/ nice advance math software that any teacher would envey. It comes with the ti83 keypad plus software and great instructions to help the instructor at all levels of math learning. I don't know any better and it is a beautiful plan that ti has set up.
Apr 03, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-Nspire Graphic Calculator Logo
373 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
