The ON button on my PC tower got stuck so I pulled the front cover I think I pulled it to hard and the wires came out. On the end they have these small box kind of thing that say(POW LED)(HDD LED)(POWS/W). Where do I plug the wires back into I know how to take the cover of, but I don't know there to fit it into. PLEASE HELP!!!!!!!!!!! URGENT!!!!!!!!!!!!
  • Anojan Oct 28, 2008
    Thank you it worked a treat. Its a relief it works. I really apreciate
  • 326 Answers
Youll need to open your tower to fix this, if you open your tower and look on your motherboard youll find an area that has 2 lines of pins with about 6-8 pins on each line (diferent motherboards vary)
you will see next to the pin the corosponding text on the motherboard (HDD etc) see the image attached. you might not find your block connector in the same place but you get the idea.
let me know how you get on
Posted on Oct 28, 2008
  • mark hudson Oct 28, 2008
    glad i could help you and thanks for rating this :)
Lost power button got turn off
try this; carefully detach (pull off) the front panel of the base tower unit.. and behind the plastic front that you just took off there's a little button that you can push to power off and on. The power button just goes through the plastic cover and pushes the button.
Jan 04, 2016 | Gateway Computers & Internet
How do i remove the front cover of my dell computer tower 8250
Not sure if you can pull the front cover off this particular model, but to open the PC:
  1. Make sure the PC is powered off and disconnected from the AC outlet.
  2. If facing the front of the PC, lay it on its right-hand side, so it lies flat.
  3. At the back of the PC at the top left, there is a release button. There should also be a release button on the bottom of the PC near the rear (slightly indented into the bottom). While pressing both of the release buttons, pull the cover upwards and the case will open like a clam.
Jul 18, 2014 | Dell Optiplex GX150 Tower Computer - 1GHz...
How to remove hard drive from dell tower
Open clam-shell type case by pushing buttons on rear top and rear bottom of case and pulling case open like a book. Once case is opened, you\'ll see the hard drive in the right half (as viewed from the back of the PC) Pull the power and data cable from back of the hard drive. Squeeze ends of green plastic slides and pull hard drive from enclosure.
Apr 21, 2014 | Dell Dimension 8300 PC Desktop
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
The PC on/off button (push in button) is stuck & the PC lights go into blink mode.
Most newer PC Towers have a front panel that can be removed exposing the push button mechanism. Check to see if yours does. If so remove the the front panel/bezel. You will see the mechanism that actually pushes the on and off button post. Check the spring mechanism to see if it may be broke or just out of alignment. If you are unable to remove the front cover/bezel then the switching mechanism is inside the tower and should be taken to a repir shop for repair or replacement.
Dec 12, 2010 | Computers & Internet
Azza Orion front fan problem
Put some oil in the fan motor or check if any wires may hitting in the fan while running
Jun 15, 2010 | Azza Orion 201 black/silver SECC Steel ATX...
The Power Button on the front cover of the PC tower no longer turns the PC On!
check on the back of the pc tower where the power cable plugs in, there may be a small switch that needs turned on again, failing that i would open the tower and trace the wires back to the mainboard one may have come loose
Jan 25, 2010 | E-Machines T2642 PC Desktop
I need to replace the power button on a Gateway E4000 mid size to
I think you will find this site useful in assisting you with removing the cover. I think you can scan directly to pg 107 for the "mid-tower" http://nzr.mvnu.edu/facilities/items/gatewaye4000manual.pdf
Mar 26, 2009 | Computers & Internet
Gateway Model 0019401806 Tower - Power button fell into case
there are tabs inside the case that you depress to pull the front cover off. once pulled off you should be able to replace the switch.
hope this helped
please rate well.
Mar 06, 2009 | Sony PCV-RS620G PC Desktop
Philips hdd 1630
The battery in the HDD1630 can be changed, but it's a bit fiddly to do.
Remove the hex screw from the back of the casing.
Gently lever the back cover off by insert a small flat blade or metal strip in between the front and back cover at the top. (Do not try to pull it off from the bottom.)
Tape along the buttons and switches down both sides of the player, so they don't fall out when you remove the front cover.
Undo the four cross head screws in the corners of the inner panel.
Gently ease the inner workings away from the front casing. Note the ribbon cable to the front panel.
Ease the buttons on both sides away from the inner casing. They are only stuck down with double sided tape.
Lift the metal plate away from the battery and hard disc, taking care not to pull the microphone out of the plastic end cap. (If it is pulled out, it can be stuck back in place on re-assembly.
Carefully lift the battery away from the board from the end opposite the wire. Pull the battery connector out of the socket and replace.
Re-assembly is the reverse procedure.
Feb 13, 2008 | Philips HDD1630 MP3 Player
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
