Question about Toro Garden
Fuel line diagram for Toro 51906 string trimmer
Model# 51906. Need fuel line diagram
  • 246 Answers
SOURCE: Fuel line for Toro trimmer
Hello:
You can Purchase Fuel Line for Trimmers and All Lawn Equipment at your Local Small Engine Service Center or your Local Automotive PArts Retailer.
Take a Piece of the Old Fuel Line so you Purchase the Correct Size.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 26, 2009
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
  • 279 Answers
SOURCE: Need to replace both fuel lines coming out of tank
All tanks have a filter inside. Some must stick through the tank and be secured by a collar on the outside of the tank and on the fuel line. If you have that type, remove the collar and slide it down the line. Push the filter into the tank. With the fuel line loose from the carb, pull the filter out through tank filler hole. If you are going to change the filter, take the new one, insert the pointy end into the line until it is seated. Next, cut the other end of the fuel line on a diagonal (makes it easier to start into the hole) start the end of tube into the same hole that the filter was in. With the aid of your finger/s in the tank and pulling on the tubing, get the line in and the end of the filter through the tank. Slip the collar over the tub and push the collar up over the filter end and push it as tight as you can to the tank. If the filter just lays in the tank, all you need do is remove the filter and line through the filler hole. Again cut the new tubing on an angle.Feed the exact amount of tubing you are replacing and connect to carb. The return line has to be in the tank far enough to hold and connected to the carb. And, Walla! You are done. Good luck...Lee
Posted on Sep 03, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
  • 83 Answers
SOURCE: 32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Posted on Sep 10, 2009
Trimmer works sometimes and other times it won't. When it works it is only for a few minutes then it stops like a switch was shut off.
Sounds like fuel issue. Check the fuel line for cracks. Also the diaphrams in the carburetor could be deteriorated due to Ethanol. Soak and rebuild.
Sep 16, 2012 | Toro& Electric String Trimmer
How far in the gas tank does a toro trimmer fuel line need to go -- I assume not very far and not as far down as the filtered gas line, correct?
The gas line with the weighted fuel filter on it should lay across the bottom of it (somewhere near the opposite side) and the purge/return line only needs to enter the fuel tank 1/2" to3/4" to work.
Sep 11, 2011 | Toro Electric Trimmer
What size string does the 910 toro electric trimmer take
12' .050 trimmer line, like that shown at the link below
http://www.google.com/url?sa=t&source=productsearch&cd=1&ved=0CFkQgwgwAA&url=http%3A%2F%2Fwww.amazon.com%2FToro-88075-12-050-Trimmer-Line%2Fdp%2FB0000CBITQ&rct=j&q=910%20toro%20line&tbm=shop&ei=h2HNTd7aCunc0QGq_aDgDQ&usg=AFQjCNF826-xPNQy9XomBFrklrqkvIHGCQ&cad=rja&biw=1280&bih=630
May 13, 2011 | Toro& Electric String Trimmer
What causes a 2 stroke engine to have too much compression and therefore difficult to pull the recoil starter?
Nothing will do this...what is most likely the problem is either the recoil is going bad or you have the wrong spark plug installed.
Dec 03, 2009 | Toro& Electric String Trimmer
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
402 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
