Question about NEC DTU 8D-2 Corded Phone
Change time & Date
How I change the time & Date???
  • 149 Answers
Feature 9 # than enter the time. Hold changes to the date and feature saves. ldtsnj.com
Posted on Jan 02, 2009
How do i change the time
For Windows 10 following these steps to change the time and date:
1. Right click on the time (Normally at the bottom right-most corner of your screen, on your start bar)
2. Select Adjust date/time
3. Press Change (Button under Change date and time text)
4. Set the time/date, and press Change
You can also change your timezone, daylight savings and automatic internet vs manual time on that setting page.
Nov 08, 2017 | The Computers & Internet
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
Set clock on computer
  1. Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
  2. Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
    The Date and Time dialog box appears.
  3. Click the Change Date and Time button.
    The Date and Time Settings dialog box appears.
  4. Enter a new time in the Time field.
    You can also use the up and down arrows next to that field to change the time.
  5. If you wish, click on a new date in the calendar display and then click OK.
    You can also change the time zone, if necessary.
  6. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
    If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
  7. Click the Change Date and Time button.
  8. Enter a new time in the Time field.
  9. If you wish, click on a new date in the calendar display and then click OK.
  10. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
Jan 20, 2017 | Computers & Internet
Change the date and time
Good day!
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Mar 28, 2014 | Computers & Internet
Need to change time on my toshiba laptop pc
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Feb 07, 2014 | Toshiba Computers & Internet
DATE -TIME RESET??
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings.
Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
David
Jun 10, 2013 | HP Compaq Presario V2000 Notebook
How do you change the date and time on a Ricoh 3800L fax machine?
To change the date and time on a Ricoh 3800L:
Press the Function key, 6222291, Yes. When the date appears, use the asterisk (*) and pound sign (#) to change the month and to change AM or PM, and use the keypad to change the date, month, and time.
Press Yes Function when you've got it set and want to save it.
Dec 23, 2008 | Ricoh FAX3800L Plain Paper Laser
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
System date and time does not change on my laptop
What do you mean it "does not change"? Have you tried to change them using the Control Panel applet, or by clicking on the time in the taskbar and trying to change it there? Or, do you mean the date and time is not incrementing at all while watching the time?
Mar 23, 2008 | Computers & Internet
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
NEC DTU 8D-2 Corded Phone Logo
379 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
