Question about Dayton Heating & Cooling
Where is my pilot located on my reznor hanging garage heater located
Can`t find my pilot light
  • 587 Answers
SOURCE: My honeywell gas suspended garage heater will not
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Posted on Sep 10, 2009
billyvangogh
  • 108 Answers
SOURCE: reznor model# f125 pilot won't stay lit. i
Make sure the pilot is clean (Blue flame fully enveloping the top portion of the thermocouple) if its dirty the pilot will be yellow like a candle and barely touching the thermocouple ...quick fix is knock the pilot with a screwdriver...gently tapping it...knocking the dust out and getting a better pilot....the pilot could also be too small if its not making good contact with the thrermocouple....there could also be an Auxillary limit wired into the thermocouple which when open will prevent the magnet from staying closed....if all looks fine then the Gas Valve itself is likely gone (The magnet inside is not field repairable)
Posted on Oct 25, 2009
  • 15 Answers
SOURCE: I have a Dayton 3E404D hanging heater in my garage
FOLLOW THE ALUMINUM 1/4 INCH TUBING WHICH IS THE PILOT TUBING WHERE IT ENDS IS WHERE U LITE
Posted on Jan 02, 2010
SOURCE: Old reznor gas heater lights up but fan does not
Hi,usually when a heater doesn't "Kick in" it has got to do with the thermistor and or thermostat. The actual thermistor is the best place to start. However with older gear, it is very prudent to get it checked out professionally, as any problems may be fatal... there are indeed strict laws regarding the servicing of ANY Gas equipment due to the possible dangers associated with any mistakes, that said though there is no reason why one cannot check and replace these components, just be careful and follow any instructions.
Also sometimes the regulators can become faulty, this is another thing to remember to check.
If the Fan isn't working then most likely it to do with the thermostat or maybe it is the BI-metallic strip or Thermal Fuse, or the main controller, or the actual fan motor itself, or perhaps if a capacitor if used, this too may gone faulty, one simply has to work through and test each part to isolate the exact cause.
http://homerepair.about.com/od/heatingcoolingrepair/ss/gas_furn_trblsh.htm
http://home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Above please find a couple of useful links to assist you.
Posted on Oct 27, 2010
  • 224 Answers
SOURCE: Model MH25NG Radiant Garage heater
Your problem lies in the gas valve, it looks as if the solenoid is stuck in the open position.
Posted on Dec 13, 2010
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
Smell gas in garage after reznor heater shuts off
sounds like the gas valve is leaking through.
have it checked out asap gas leaks only get bigger.
Feb 12, 2015 | Reznor Hanging Furnaces-Power Vented-...
Have a Reznor propane heater, suspended, the pilot light ignites, though the ingniter runs continuously, thepilot light burns for about 2 minutes then everything shuts off, never ignites the main burn
First clean the flame sencor if fitted jump out the pressure switch see if thhelps , Also there are two snap discs high and low temp try jumping these out 1 at a time .
Mar 12, 2013 | Heating & Cooling
I have a Reznor heater that hangs from the ceiling. I can lite the pilot, turn the t-stat to call for heat, it fires up, and will run as long as it calls for heat. When it reaches the set point, and shuts...
Check pilot is not blocked may needed cleaning out it sounds like the pilot is lifting off when the burner is on and when it gets to temp it shuts of as pilot may not be there , also check thermocouple is tight , or flame sencor is clean ( if fitted )
Mar 09, 2013 | Heating & Cooling
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
Reznor model# f125 pilot won't stay lit. i
Oct 25, 2009 | Heating & Cooling
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
Heating & Cooling Logo
740 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
