Question about John Deere Garden
I have a john deere sabre model 1338 gear, wen i leave the clutch out or engage the mower blade the engine dies, could it be one of the saftey switches.
  • 11 Answers
SOURCE: John Deere LT 133. Will not move with mower in gear and clutch/brake released. A smell like hot rubber prior. Mower will engage. Thanks.
It could be that the belt jumped off the pulleys and got caught between a pulley and a belt guide,or the trans-axel seized up ,or brake was stuck while in a high gear,and burned up the belt. most likely the first reason. if it wasn't for the burning rubber smell,I would also look for a broken clutch/brake return spring .The pedal would stay down with a broken spring
Posted on May 24, 2009
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
  • 5 Answers
SOURCE: John Deere LA110 mower blades got disengaged
does it engage manually with a lever, or is it electronic with a push pull switch? if electronic, check the wire that goes to the electric clutch, it might have come off when unplugging it. do all this with the engine off
Posted on Jun 27, 2009
bargainbin2
  • 123 Answers
SOURCE: need a diagram on how to put a drive belt back on
It is a hard one to put on co look at the picture carefully there are two pulleys one that one side of the deck that are trickey.
Posted on Sep 01, 2009
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Oct 25, 2012 | John Deere Garden
Mower dies when pto is engaged blades move freely
Could be the seat switch. Your operator present switch only comes into play when the clutch is engaged. If the drive clutch is engaged, and the pto is engaged, the operator present switch has to be moade.
Aug 03, 2010 | John Deere Garden
John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Oct 02, 2009 | John Deere Garden
Blades wont engage on a john deer riding mower
May be a safety switch not letting the PTO engage the clutch? Also check your voltage at the battery...too low a voltage won't let the clutch engage either. Should be between 13.3-14v at full throttle.
Sep 09, 2009 | Garden
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
May 25, 2009 | John Deere Garden
Garden Logo
77 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
