Question about HP Compaq 1501 15" LCD Monitor
Power supply for Compaq 1501 15" LCD Monitor
Monitor Compaq 1501 15" LCD
My friend got me a monitor 1501, but didn't find the DC power supply. Now I have bought a supply with 12 voltage, 3,3 amphere, but there's two possibilities to connect to the power supply: + or - How do I know who's the right? Can I damage the monitor if I connect the wrong way?
  • creamus Oct 29, 2008
    Yes, into the monitor it's only one solution, but on the little thing you put into the monitorconnection there are two possibilites ("+" and "-"), the cable fit to both... which one is the right?? The power supply is not the original one for Compaq 1501.
    Normally it should be a sign on the monitors backside or in the manual of the monitor, but I've checked both, and it isn't...
  • creamus Oct 30, 2008
    I've got the manual for the monitor Compaq 1501 as a pdf-file, but in that file there is nothing written about polarity for the power supply...
Arrange the manual from any where with same model and find it .without looking directly i cannot advice anything try to understand
Posted on Oct 30, 2008
  • 348 Answers
The connecter of monitor will not fit wrong way it can fit only right way so no possibility to damage the monitor
Posted on Oct 29, 2008
  • pravin bhavsar
    pravin bhavsar Oct 29, 2008
    the connecter of monitor will not fit wrong way it can fit only right way so no possibility to damage the monitor
  • pravin bhavsar
    you have to open monitor signs can be observed at left look signs and then connect proper poles according to signs
Screen has gone very dark
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 10, 2010 | Compaq Computers & Internet
Compaq cq60 - screen black - laptop on
Sep 08, 2010 | Compaq Presario CQ60-220US PC Laptop
The srceen stays black
Sep 06, 2010 | HP Compaq Presario V2000 Notebook
Compaq 1720 monitor: the green light on the power supply went away, the voltage converter was very hot and the monitor went blank
You need to find out if the power supply is still putting out 12vdc, you may have to test it with a load (use 12v car bulb such as the brake lamp). It is getting hot can be due to bad power supply or too much load because of short circuits in the monitor. Please post back what you find about the power supply first.
http://www.unitedsale.com/AC-adapter-Power-Cord-Charger-12V-35A-For-Compaq-1720-LCD-Monitor-Brand-New_p_219.html
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 03, 2010 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
My compaq 610 laptop is not displaying when it is on but it keeps on running
Aug 30, 2010 | Compaq Presario Notebook
My compaq presarion c-500,it is showing power on but display is not showing on.
Try an external monitor & see if it will work. If it does, then this might be a sign of a faulty LCD cable or screen inverter board.
Aug 29, 2010 | Computers & Internet
A menu keeps flashing on my monitor so fast I can not read it and it will not stop. Black box with grey edge. Compaq 5017M monitor
mrsrobins849, if monitor manufacturing date (on rear of unit) is anywhere close to 2003-2004 then trade unit for new wide screen only if problem of flashing "menu" goes away when you connect a borrowed substitute monitor to your pc. Will your monitor "act" same when connected to "known-good" "fully-booted" pc that will display the WIN-desktop?? Most problems with "cold-cathode-fluorescent-lamp" "back-lit" lcd monitors can be attributed to their internal or external "switch-mode-power-supply" DC voltages degrading over time with use.
12fixlouie
May 28, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
Flickers until all monitor area turns gray - just like tv without signal
Sounds to me like bad caps on the power board or main board.
The monitor is faulty for sure. Bring it back to the shop and tell them the problem is still happening and ask them to leave it on connected to a computer overnight since it takes a while to happen. They should see it happen and then troubleshoot it further.
May 26, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Got flat screen as a gift
This monitor requires a power supply with a POSITIVE tip polarity.
Monitor requires 12 Volt DC @ 3.3 Amps output.
Make sure voltage is 12 Volts DC [absolute requirement]
Power Supply can have greater than 3.3 Amp capacity. More amp capacity increases price, so I wouldn't go for more than 5 Amps [minimum 3300 milliAmps, 5000 milliAmps will be more than adequate].
Put a surge protector on your computer and monitor to extend their life....better yet, a power conditioning battery backup system, that can supply constant voltage, to compensate line voltage when A/C, furnace, or other major appliance kicks on.
May 04, 2008 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
HP Compaq 1501 15" LCD Monitor Logo
705 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
