I need to replace the opc belt in my printer. is this somthing i can get on myself and replace it? or do i need an expert to do that? and how much does it cost?
    Genius:
  • 2,120 Answers
You need a technician.
Posted on Oct 28, 2008
Error msg appear set belt cg dont know what to do.. am i have to replace the photodeveloper cg?
The error can either be caused by the OPC/OPC Marker assembly or the Main Motor assembly. Please follow the recommended troubleshooting steps:
  1. Power the printer off, remove and reseat the OPC unit, and power the machine back on. Print a test page. If error continues, proceed to step 2.
  2. Power the printer off and remove the OPC unit. Check the OPC Marker Sensor. If it is unsnapped or unplugged, reseat or replug it, and power the printer back on. Print a test page. If error continues, proceed to step 3.
  3. Remove the OPC unit and check it for scratches or defects. Also check the the markers on the OPC to make sure they are not damaged. Is the belt scratched or damaged? If the OPC is at or near the end of its life, OPC unit must be replaced. If the belt is in good condition, contact Lexmark technical support (if printer is under warranty) or your local authorized service provider for assistance.
Sep 30, 2010 | Lexmark C500n Laser Printer
OPC belt is replaced and has 100% life but the OPC
make sure all components are properly seated. also try turning the printer off and waiting a few minutes and turn back on.
Aug 19, 2009 | Brother MFC-9420CN All-In-One Laser...
Replace belt CG
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
May 28, 2009 | Tally T8106 Laser Printer
MFC-9420CN All-In-One Laser Printer Install OPC belt message
Perhaps your OPC belt is at the end of its life and needs replacing
Apr 07, 2009 | Brother MFC-9420CN All-In-One Laser...
OPC Belt needs replacing
Try pressing 1 and 7 at the same time
The LCD will show "OPC belt 1. Reset 2. Exit
Select 1 to reset the life counter.
This is supposed to be done when replacing the drum unit...but I've found that I can get 1.5 to 2 lifespans from a single unit.
Jan 31, 2009 | Brother MFC-9420CN All-In-One Laser...
TALLY GENICOM 8008
The SVC E9 error indicates a 'BELT MARKER' error.
This means the printer is not detecting the OPC Belt as rotating.
This error can be caused by a damaged OPC belt, you can check this by removing the OPC belt from the printer and look at the OPC belt it should have a smooth green coating if there is damage to this belt it may cause this error.
The error can also be caused by a damaged 'Transfer Belt' when the OPC belt has been removed from the printer look inside the printer where the OPC belt used to be located you should see a black belt towards the back of the printer, if this belt is damaged it can also cause the error.
Ensure the OPC Belt locates in the printer correctly.
If the OPC belt and Transfer belt look to be free from damage and a are located correctly in the printer you may have a faulty belt marker sensor or faulty OPC belt.
You can try substituting the OPC belt for an alternative one if you have this available to see if you can narrow the problem down to the sensor.
Jan 23, 2009 | TallyGenicom 8008 Laser Printer
NO OPC BELT on MFC-9420cn
The opc sensor is not sensing the belt. Open the front cover and remove all the toner trays. You will see the green OPC and the sensor is located in the left upper corner. Also open the top cover and remove the OPC. Clean the sensor with a soft bristle brush. Also make sure the OPC left side is free of toner deposits. This may incorrectly trigger the OPC position sensor. Hope this helps.
Jan 14, 2009 | Brother MFC-9420CN All-In-One Laser...
What is opc belt 2700 CN printer
the opc belt is the optical photo conductor belt in your printer. It is the bright green shiney belt you see when you remove a cartridge. You can access it through the top of your unit. You will see a cover where the paper comes out. Inside there are two green clips that push outward. These release the opc belt.
You can purchase a replacement opc belt from most good stationary and consumable suppliers, however, be ready for a shock. the price of the opc belt is almost as much as the unit is worth.
Dec 12, 2008 | Brother MFC-9420CN All-In-One Laser...
Is the massage replace the cg belt the same as the ocp message as i can't see any damage to them at all.
You are correct the 'Belt CG' is the OPC belt cartrige. The mesage advising this item needs to be replaced comes up as the result of a page counter in the printer. The mesage comes up as a result of the page counter exceeding the maximum number of pages expected from the OPC, ensuring reliable print qulaity.
The message does not indicate the OPC Belt is damage, it has reached the end of its designed life.
Aug 26, 2008 | TallyGenicom 8008 Laser Printer
54 people viewed this question
jasbo
jasbo
