Question about Garmin Forerunner 410 106 in Handheld GPS Receiver
Forerunner 410 not charging
We have a new forerunner 410. It does not appear to charge. After 3 hrs the screen is still blank. No pressing, touching gives any result
5 Suggested Answers
SOURCE: Forerunner 305 won't charge
Had the same problem. Turned out I only *thought* it was the cradle and/or cable being finicky. Actually, the problem was one of the four contact points on the back of the 305 had oxidized and if all 4 don't make good contact with the cradle, it won't charge. Apparently, manipulating the cable only coincidentally helped, if/when it did help, perhaps by subtly shifting the contact point so that a less oxidized part made contact.
Anyway, rubbing the contact points with a pencil eraser cleans them enough to get a good charge. I've had to break out the eraser every 2-4 weeks.
Posted on Jun 15, 2008
SOURCE: Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Kenny
Posted on Dec 10, 2010
JohnE5
  • 34 Answers
SOURCE: Garmin Forerunner 201
Try a reset. Hold the reset and power button for 30 seconds.
Posted on Jul 11, 2008
  • 81 Answers
SOURCE: My Garmin Forerunner 305 quit
Try hard reset.
Hold mode + start for ten seconds (device off beforehand). Keep holding then pulse push lap/reset button.
You get a screen asking to return to default settings. You will loose all your data, but device should work then
Posted on Sep 26, 2010
Garmin Forerunner 210W screen is blank. No charging symbol appears when it is on the charger.
Not sure if this is useful but double check that your charger connection to the Garmin is actually clean. I've had to clean the contacts for both my 405 and my 610 in order to make sure there was a solid electrical connection. Have you tried resetting it?
Feb 20, 2014 | GPS
Yesterday i download the forerunner 205 software from the garmin website. after i connect my unit using usb to the computer, my garmin won,t power on immediately. i tried to reset it (soft and hard reset)...
Did you install the software correctly? Because such errors appear usually when the update/upgrade is not finisher or was not done in a proper manner.
If possible try to verify the device on another computer (a friend's) to see if the same problem appear.
If the problem persists I'd say you've burned out your battery (hope not the hole Forerunner...!).
Mar 05, 2011 | Garmin Forerunner 205 GPS Receiver
My forerunner 205 was charging just fine until I pressed the power button. The screen went blank and I cannot turn it on. Does this mean the battery needs to be replaced. If so, how does one go about...
Probably it is not due to the battery.
Your device is crashed. Perform soft reset :
press & hold mode plus lap/reset keys for 10 seconds, release then press start long enough until device starts.
Sep 26, 2010 | Garmin Forerunner 205 GPS Receiver
It is totally dead and will not charge.
Had same issue... this worked for me:
1. Snap into charger base & plug into wall. Screen still blank. 2. Press Lap/reset, Mode, & Power buttons all three at the same time & hold for 3 seconds - unit will reset. Hopefully then you'll get the 'charging in progress' message.
(also make sure copper points/connectors on unit and charger base are clean).
Aug 28, 2010 | Garmin Forerunner 305 GPS Receiver
Won't turn on or charge
Press Mode (bottom left side button) and Reset (left front button) simultaneously, let go, then press On (top left side button).
Jul 28, 2009 | Garmin Forerunner 305 GPS Receiver
Hope this helps!!!
Kenny
Feb 20, 2009 | Garmin Forerunner 205 GPS Receiver
I have a garmin Forerunner 405 and the time was locked at 7:25 am.  I held the two side buttons down in an attempt to reset it, and it just cleared the screen completely.  I charged it last night, and the...
Hi
I had a similar problem, the screen lock while trying to turn GPS on. Tried all butttons and bezel operations, left it charging overnight - no joy. Eventually pressed and held both buttons and after about 30 secs (did not time it but was about that) it restarted.
AllanD
Jan 16, 2009 | Garmin Forerunner 405 Handheld GPS...
Mar 11, 2008 | Garmin Forerunner 201 GPS Receiver
Garmin Forerunner 410 106 in Handheld GPS Receiver Logo
1,502 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
