Question about Jazz Jellies 207 35mm Point and Shoot Camera
Lost battery door
The little cover that flips over the battery at the bottom of the camera fell off and is lost. Is there any way to get a replacement? Without this battery door there is no connection to use the flash. If there is no replacement part, is there a comparable camera to replace the Jazz jelly? She gets great pictures with this, and it was at such a great price.
    Top Expert:
  • Jazz Master
  • 12,962 Answers
Surely you can use a little duct tape or something else to secure the battery in place. You might want to contact the manufacturer to see if they have the part or you can check on ebay under the camera model to see if some parts are also listed. Happens on many occasions..
Posted on Sep 23, 2017
SOURCE: jazz dvk 141 digital video camera
Digitron/Jazz Products LLC: 1-800-983-7004
Shipping Address:
Digitron Repair Centre
110 Ethel Road West, Unit 2
Piscataway, New Jersey
08854, USA
Posted on Nov 18, 2008
JSEhandyman
  • 368 Answers
SOURCE: Deleting pictures from my camera jazz JDC31 Digital camera
Hi sjadl2840,
I presume you've already saved those pictures you want to keep in another location and you want to flush everything in the camera.
Typically, you have a button on the back with a little trash-can picture next to it. Pressing that will put you into Review/Delete mode. You will usually need to use the up/down/left/right arrow keys to navigate to select the photos you want to delete. Selecting the "OK" or "select" button will select that photo for deletion. You will typically have to confirm deletion for each photo, or before deleting all (if your camera provides that option in it's programming).
These instructions are somewhat generic; if they don't work for you, respond with a comment, and we can zero-in on your specific situation.
Beyond that, if I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Posted on Dec 29, 2008
SOURCE: how do i erase the pictures stored in my Jazz JDC
press menue/on/off until the LCD will display garbage can symbol, then press shoot once, until 888 blinks and press shoot again to validate your choice, then all photos saved to the memory are deleted.
Posted on Mar 29, 2009
  • 63 Answers
SOURCE: I need a free driver for my jazz jdc9 camera .
Look exact model and try to search the driver through search system.
http://filters.atspace.com
Posted on Aug 10, 2009
jadendale
  • 4 Answers
SOURCE: Battry charger
i lost my charger for my jazz hdv 178 camera and i dont know how much another one will cost,do you know how much they cost and where i can probably get one.
Posted on May 31, 2010
Camera will not power on
Assuming that the battery is OK, there are two switches that if not operating the camera will not power on - one for the SD card door and one for the battery door. Both must be closed for the camera to power on. Also, the main switch is a micro switch. You can see the battery door switch with the door open. Carefully check to make sure the little arm is closing. Sometimes if the battery door is worn it will it not close enough to close the switch - try pushing up the battery door all the way and see if it then turns on. You would have to remove the back cover to check the on/off switch, and to replace it you have to replace the entire back cover assembly. The other common cause is one of the bottom board screws coming loose and shorting the board. Most of these problem require professional repair, but if it is the battery door you can usually find them on eBay.
Jul 07, 2014 | Canon EOS 60D Digital Camera
I don't know how to open the battery door for the
Slide the latch in the center of the battery cover toward the front of the lens, then flip open the cover. It's hinged toward the center of the body, so it flips open in that direction.
There's an illustration in the "Preparations" section of the Basic manual (page 5 in my copy). If you need manuals, you can download them from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a630#BrochuresAndManuals
Aug 11, 2011 | Canon PowerShot A630 Digital Camera
I have a Flip mino hd. Battery is totally dead and I cannot get it to charge. I have used my computer USB and my friend has loaned me his Flip charger. NOTHING! Should I throw the camera away? I cannot...
Try a different USB port and don't use an extension cable with it either. Make sure the computer you are using is turned ON and stays on during the charging. not sure about the second half of your question, not knowing how to open? and change the battery? If you never opened it to begin with how did you get the rechargeable battery pack into it?? they don't come installed. battery was separate in the packaging on mine. anyhow, there is a little slide button at bottom of camcorder slide the opposite direction, then the whole front of the camcorder slides down and off of the camera. The battery pack goes in. the White plastic that covers both batteries Stays on them do not remove, but if there is a little plastic strip covering the connections remove that. I have the Ultra HD and it also takes regular AA batteries, and you may try that too to see if it will work your camera, if not, maybe something is wrong with the camera.
I am hoping you did not think the rechargeable batteries were already in the camcorder and they got thrown away with the packaging !!!! IF so, then use AA batteries instead. good luck. :)
Dec 08, 2010 | Pure Digital Flip Video Ultra Camcorder
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
I dropped my camera and the "card/battery" cover fell off of my camera, I got it back on, but now my camera wont turn on, I cant view pictures or anything, its just dead, The battery is fully charged. Any...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. As you mentioned the door fell off, would recommend focusing your attention on inspecting the door switch and the plastic nib that pushes in on it. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Apr 28, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Dropped SD750 on floor, now won't turn on
That's a hard one to analyze through email. A camera tech would have to use test equipment on it to see if the power section got shorted when the door opened when it hit the floor. It may not be a cheap or easy fix, but only a tech can tell. I have heard of cameras getting damaged, just from putting batteries in backwards, so a short circuit might have damaged a chip inside. Of course a warranty does not cover dropped cameras, but you might want to have them look at it and tell you what it will cost.
Sep 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Flip video won't charge
If you look on the bottom of the camera there is a button that slides from a locked to an unlocked position. Slide it to unlocked and then slide down the back of the camera (the side with the lens) there is a removeable rechargeable battery pack. Remove it for a moment and then put it back in. Try plugging back into the USB port. This should work.
Jan 09, 2009 | Pure Digital Flip Video Ultra Camcorder
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Jazz Jellies 207 35mm Point and Shoot Camera Logo
43 people viewed this question
Top Jazz Cameras Experts
wgenglan
Level 1 Expert
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
