Canon iR Advanced 2030i error E000020-1160
Canon imageRUNNER ADVANCE C2030i indicate the error code E000020-1160. What does this error mean?
I faced with this error when the all print drums have been replaced by new. Then I put old drums and had replaced one by one then I found that magenta drum had a factory defect. I solved this problem by replacing of the old chip to the new drum.
Posted on Jan 03, 2014
SOURCE: e000020-0010
reinstall the toner. go to service mode select COPIER>FUNCTION>INSTALL>TONER-S>START>OK
Posted on Aug 03, 2008
spinal
  • 287 Answers
SOURCE: CANON IR C6800
Hello Jc.Let me start by saying that despite the fact that you have properly been specific with the error code you have submitted, Canon is "fairly" specific in regards to the amount on detail in provides. I say fairly in really loose terms. The error 602 means that for any number of reasons when the copier went to boot" (begin to start up and read its directions as to what it is, who it is, and what it is capable of, it failed to get the instruction set (or failed to recognize the instructions) and therefore said "what"?!) as the copier sought to retrieve this info from the hard drive.That can mean that the partition of the hard drive that is was looking at contained corrupt information, or there was a communication interruption, or that the hard drive is going or gone bad. I know this sounds like a bunch of technical goblidy gook but you don't want to know what the 0101 means after the 602. It may not be too bad but brace yourself for the worst. That is that the hard drive may have went wheels up, or at a minimum all stored custom information is gone. The latter may be the best you can hope for. I am afraid that a "hail Mary" might be to power the copier of by way of the rear switch (or unplug if you are not familliar) and wait a few minutes.Restart and hope for he best. Otherwise you WILL need a technician to replace the hard drive and then they will have to reload the system software. I was reluctant to respond to your request for help as I cannot "fixya" and I will get a bad grade from the guys that run this site since I left ya hangin. But I could not resist trying to help you and to at least make sure you did not get raped by some "hungry for money" company. Please at least give a decent rating and I will keep my fingers crossed for you..................SPINAL
Posted on Jan 25, 2008
KyoDoc
  • 38 Answers
SOURCE: Cannon IR C5800
According to my info this is an error detecting the home position of the image transfer belt. It may be a problem with the sensor or one of the boards, but there is also mention that if there is paper in the mbypass tray in low humidity environments that due to static electrcity electrical noise may occur and result in the incorrect detection of the ITB home position.
I would say first step is if you have paper in the bypass tray, remove it and restart the machine and see what happens. If your problem still perists i would recommend that you have a Canon Techncian come out to have a look
Posted on May 10, 2008
SOURCE: Canon ir 3100 cn error code e000020-0081
I just had mine serviced for the same code if you take the drum out and wipe the sensor inside the unit that should do it
Posted on Aug 14, 2008
  • 3 Answers
SOURCE: Error Code
check the registration motor and right door or door switch
Posted on Dec 12, 2008
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
Canon ir error
Hi javan,
Go To Below official Canon Printer Page For Your problem,
Canon imageRUNNER ADVANCE C5051 C5045 C5035 C5030 Manual List of Error... Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 07, 2014 | Office Equipment & Supplies
E000020 1360 canon error code after changing drum unit.
This has been fixed by replacing the memory chip on the drum. This may meaning replacing the drum. First though, try cleaning the laser and make sure all your drivers are upto date:
http://www.canon.co.uk/support/products/imagerunner/imagerunner-advance-c2025i.aspx?type=drivers&language=&os=OS%20X%2010.11%20(El%20Capitan)
This may be a call to canon support unless you are very confident with these procedures.
Part number for the drum is Canon C-EXV34
May 23, 2013 | Office Equipment & Supplies
Our cannon ir has the error code E002... what does that mean? The model is 330s. And how can we fix it? Thanking you in advance.
that is mean problem with thermistor.
you must replace a new.
position is inside near exit paper place.
May 18, 2011 | Canon ImageRUNNER 330s Copier
We have a Canon Image Runner C2880 with an error code of E00025-002 What does this mean and how do I fix it?
This is error in the toner motor. The 0002 is indicating that there is error in the Cyan developing assembly toner supply. You could try switching one toner motor for the other and see if the error cahnges to the other color. The book indicates that it may be the DC controller as a last resort. Check the connection between the motor and the DC controller. Hope this helps.
0000 is yellow, 0001 is magenta, 0003 is for black.
Apr 13, 2011 | Canon imageRUNNER iR C2880 Color Copier
Error E000002-0000 what can resolve this problem
My canon 2525 is displaying error code E000002. Please help.
Apr 30, 2010 | Canon iR 2030i All-In-One Laser Printer
1,468 people viewed this question
jasbo
jasbo
