Question about Oregon Scientific FM Weather Projection Clock with Self-Setting Atomc Time and Vibrating Pillow Speaker
Barolo weather station resetting the outdoor remote sensor
I changed the outdoos remote sensor and it does not display the information on the indoor unit.
2 Suggested Answers
  • 1114 Answers
SOURCE: I cannot open the remote sensor for my Oregon Scientific PSM06AR.
I believe the back of the sensor slides open. There may be a faint arrow on the back that indicates the direction in which you push.
My unit took well over 24 hrs to reset. I think it has to do with the position of the satellite in relation to where you live.
Posted on Jun 29, 2009
My Smart Gear STG-6007-BB weather station won't pick up the outdoor temperature from the remote sensor. I changed the batteries and reset the unit, but it still doesn't work. Any suggestions?
  • Remove all batteries
  • Install batteries in remote sensor. Allow time for it to begin sending temperature information
  • Install batteries in indoor unit. You should see temperature displayed
Cold weather can cause loss of temperature information
Dec 17, 2016 | Measuring Tools & Sensors
Model WS9611UN-IT - I am unable to receive the outdoor temperature. I have changed the batteries on the outside remote but I still do not receive the outdoor temperature. How can this be corrected
Remove all batteries, both outdoor and indoor. Install batteries in outdoor unit and wait for it to begin sending a temperature signal. Install batteries in indoor unit. You should see outdoor temperature displayed. If not, batteries, transmitter, or indoor unit may be defective.
Nov 16, 2016 | Measuring Tools & Sensors
Will not transmit outdoor info. Batteries good- LED lights. Monitor shows indoor temp only.
There are a couple of possibilities for the failure to transmit/receive outdoor data. First, resynch the two units. This will depend on the manufacturer. For some brands, you need to take the batteries out of both the indoor and outdoor units for 10 minutes. Then put the batteries into the devices with both side by side (working inside is easier). Wait until the outdoor data is displayed. There are some weather station systems where the outdoor unit isn't weather-proof. You may need to dry the outdoor unit for several days after removing the batteries before resynching it to indoor sensor.
If the data displays properly when the outdoor unit is inside, you may have the outdoor sensor too far away from the indoor unit. (The distance will depend on the number of walls and the composition of the wall studs/siding.) Try keeping the two units closer together.
If the outdoor data isn't displayed when the two units are side by side and the reset procedure doesn't work. One device has an internal malfunction (transmitter or receiver failed). It's probably best to replace the unit. If it is under warranty, contact the manufacturer.
I hope this helps. For specific details on resetting the indoor and outdoor units to synch them, please add a comment with the make/model of your weather station.
(I've seen Davis Weather stations damaged by a close lightning strike. The outdoor unit had to be replaced.)
May 23, 2015 | Measuring Tools & Sensors
Outdoor temperature reading shows -40 with wind chill -62. Outdoor temp is in fact +45.
We would recommend a hard reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac, and then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall battery into the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Mar 17, 2015 | Chaney Measuring Tools & Sensors
Modelws 7013u how to replace and reset batteries
In systems with an outdoor transmitter and an indoor receiver, the usual battery replacement procedure is to start with the outdoor transmitter first, allow time for it to start sending data, then install the replacement batteries in the indoor unit. You should see the outdoor temperature being displayed.
Jan 03, 2015 | Measuring Tools & Sensors
How do I get the -- away and get the outdoor temperature to work?
You may have to "reset" it by removing both indoor and outdoor unit batteries, waiting briefly, then reinstalling batteries in the outdoor unit followed by the indoor unit. After awhile, the outdoor unit should begin sending information to the indoor unit.
Nov 20, 2014 | Oregon Scientific Wireless Weather Station...
Acurite Manuals
Remove new batteries from the indoor station. Carefully remove batteries from the remote sensor, then reinstall. Reinstall new batteries in the indoor station. DO NOT TOUCH ANYTHING FOR AT LEAST 10 MINUTES. You should see the outdoor temperature displayed and can then proceed with other settings.
Nov 03, 2013 | Measuring Tools & Sensors
I have a TX6470 and cannot receive the outside temp on the inside unit
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. If there are reset buttons, also try them.
Oct 16, 2010 | Timex TX6490 Wireless Thermometer with...
Remote sensor does not work after installing new batteries
Oct 15, 2010 | ATOMIC Digital Wall Clock With Temperature
I changed batteriers and now I can't get a reading from the remote. I have hit the reset on both units. Maybe not in the righ order.
I believe they ask you to press the reset button on the main unit first, but that may not be your problem. Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. Also, make sure the units are close enough to transmit.
Sep 26, 2010 | Oregon Scientific RMR382ABLACK Wireless...
Oregon Scientific FM Weather Projection Clock with Self-Setting Atomc Time and Vibrating Pillow Speaker Logo
91 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
