Question about Star trac Exercise & Fitness
Startrek tredmill belt is slipping
Star Trac Treadmill, Belt is slipping and added Q 8 silicone lubricant. worked for a while Then started slipping again. Did the Q8 do damage? And if it did, How con i rectify the problem?
57 varieties
  • 1653 Answers
SOURCE: HOW DO I remove silicone lubricant from the
You need to be careful if you are trying to clean the belt soa s not to damage it. Use something like methylated sprit - or some other clean that does not have oil products in it. A good qulaity computer foam cleanser also works very well.
Posted on Nov 09, 2009
  • 16 Answers
SOURCE: What silicone oil is needed on Horizon Paragon 408 treadmill?
You should be able to google the answer.
Posted on Jan 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have just been given a star trac treadmill, how
Go to www.support.startrac.com go to manuals select your model it will PDF format
Posted on Mar 01, 2010
  • 15 Answers
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
  • 910 Answers
SOURCE: Star Trac 2 treadmill. Power supply ok.
I can't find any reference to a Star Trac 2 Model.
Can you confirm from the following link using your SKU or Serial No. which is your Model.
http://support.startrac.com/index.cfm?fuseaction=prodinfo.ibp02&typ=1&sty=1&dct=&wsr=&sid=
Posted on Jul 31, 2011
I have a t9450 treadmill and have adjusted tension on belt. It now makes a loud noise when I run. The belt isn't slipping and everything else works. Noise is loud and annoying. Can't run on it....
hi,
Try to lubricate the running belt. If the lubrication is not proper then the belt will make noise. You have to use silicon lubrican for the same . Watch the following video to know how to lubricat the treadmill.
OK
Aug 23, 2011 | Exercise & Fitness
Tip
How to Change a Star Trac 4000 Treadmill Running Belt and Deck
This video will visually assist you in the procedure of changing the deck and belt on a Star Trac 4000 treadmill.
Star Trac Unisen Treadmill TR4000 Parts SPORTSMITH net
on May 15, 2014 | Startrac Fitness Products Exercise &...
I have a nordictrack 2500r treadmill and when i run on it the belt sticks to the board underneath. Any assistance would be very much appreciated thanks
hi,
Your treadmill walking belt need lubrication. For lubricating use Teflon silicon lubricant. To know how to lubricate the treadmill belt watch the following video.
OK
Aug 20, 2011 | Exercise & Fitness
While walking on my tredmill the belt jerks
Sometimes mine can "****" when my body weight on the front foot slightly slips the belt forward before I put full pressure on it and it slides back into normal walking. Don't know what your natural walking style is like, but this tends to happen when I am "heavy" on my heel with that forward step. Could also be that your belt needs lubricating (buy from sports stores).
Nov 27, 2010 | RTO Image 15.0R Treadmill Walking Belt
My belt is skipping. How do you tighten it and does it need oil
Lubrication will not stop the belt from slipping. If you do lubricate it, do not use oil, use whatever is recommended by the manufacturer, probably silicone.
It is likely your belt is stretched to the point that is needs replacement. You can order a new one through Treadmill World
Oct 05, 2010 | Icon Image 17.5 S Treadmill
The belt hangs or slips. Makes noise.
Lubrication may not be the issue, belt tension could cause the slipping at the end of the unit their is 2 tension bolts. 1/4 turn clock wise on these bolts will increase belt tension, start with 2 quarter turns on each bolt then start unit and proceed to walk on it, see if slipping has stopped. If not repeat procedure only turning the bolt 1 1/4 turn at a time until until proper tension is achieved. If the unit need lubrication then us a tube of clear silicone which you can purchase from Landice,
Call them @ 1-800-526-3423
Jul 14, 2010 | Landice L9 Cario Trainer Commercial...
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Treadmill may be slipping
Depending if this is a new issue or old, It could be a couple of issues. Check the belts for slipping. Proper tension on walking belt (check your manual) or drive belt -remove the cover and you might be able to see if the belt is slipping or it could be a load issue (electronics not sensing added load fast enough). My bet is belt tension. Also Lubricate,lubricate,lubricate
www.twincityrepair.com
Feb 28, 2009 | Reebok Exercise & Fitness
Exercise & Fitness Logo
Top Star trac Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Star trac Exercise and Fitnes Expert? Answer questions, earn points and help others
