Question about Dell Inspiron 8100 Notebook
Dell 8100 ethernet will not connect off the port replicator
Ethernet runs fine off the MX-01E530 port replicator which has its own ethernet connector, but the laptop shows "cable disconnected" when the cable is plugged into the laptop. Any hints?
  • Anonymous Feb 24, 2009
    Dell 820 Works fine on ethernet port on back of PC, but quit working on the ethernet port on the port replicator about 3 days ago.
    The rest of the port replicator works just fine.
  • 71 Answers
Let me give it a try ...
There are a few possibilities but i'll cover 2 of them :
1. There is a program that comes with your DELL that will save battery life by turning off your Network Card (LAN) I forgot what is the program name. But usually when you plug the power cable out, there will be notification at bottom right corner of your screen that told you so.
2. I don't know if your port replicator connected to power adapter (is port replicator = docking ?). The fact that your LAN connected when it's on port replicator make my first conclusion more acceptable. Since port replicator got it's own power adapter, it will just turn the LAN on.
Now if you want to check if thats the cause, just plug your notebook to it's power adapter/charger and plug your LAN Cable in. If it works than the problem is the nasty program from DELL.
If you want to disable the program just go to Startup Tab at msconfig and disable (clear the check mark) for that nasty program
Hope it helps
Posted on Oct 28, 2008
Not able to get an IP from the network when connecting thru the Targus docking station model ( APC51US) i am on windows 7. note that i am using the same cable adn it work fine when i connect it to the...
In order to use the ethernet card on your Docking Station ( or Port Replicator), you must first disable any internal Ethernet cards.
To do this:
  1. Type "Network Connections" in the Start Menu seach box, and press enter.
  2. Right click on your computer's internal ethernet adapter (i.e. "Local Area Connection" & select "Disable"
Ref: Targus Support
Apr 19, 2011 | Targus Port Replicator, Docking Station,...
Dear Sir/Madam, I have a notebook TM8572T-484G50 which I put into EZ Port IV port replicator to use it as a desktop. However, when I connected the network cable to the port replicator, it doesn't...
It appears that the ethernet connection from the laptop to the replicator is bad.
This will likely need to be serviced by a qualified Acer repair facility.
Your other option (likely cheaper too) is to simply get a USB ethernet connector to use when it's docked.
Feb 25, 2011 | Acer EasyPort IV LC.D0100.020 Port...
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
Help - does dell dimension 8200 have ethernet as standard?
As per the Dell Dimension 8200 specification, it does not have an Ethernet port to connect to LAN/Internet on wire.
check this site for more info:
http://support.dell.com/support/edocs/systems/dim8200/specs.htm#1101572
Nov 07, 2009 | Dell Dimension 8200 PC Desktop
Dell Precision M70 - Ethernet Port not recognised
if the laptop is wifi enabled there is no need o connect it through the Ethernet cable it will just pick up the signal and you will have to put in the pass code. Even if you want to connect by Ethernet cable you should be able to just plug it in and get on the internet.
if the problem is you don't know the pass code it should be on the original modem manual.
May 04, 2009 | Dell Precision M70 Notebook
Ethernet port connection failure
You could get another ethernet card from ebay for less than $10. Although, honestly, I don't think the port could have oxidized in 5 years. What is the error message(s)?
Mar 29, 2009 | Linksys Wireless-G WRTP54G Router
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Ethernet in Docking Station
Some docking stations require device drivers in order for the ports to work. Try the link bellow for any drivers that are for the docking station. They're generally under utilities or applications, but could be else where. If there are no drivers, or if they don't work, then I suggest having the port checked. It could be a bad port. Also try any updated ethernet drivers for the machine, if it uses the machines integrated ethernet, then it could be the controller driver as well.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_P3CT_8100&os=WW1&osl=en&catid=&impid=
Sep 14, 2008 | Dell Inspiron 8100 Notebook
Ethernet for my dell 4600 pc
No, you don't need a card, as long as you have an Ethernet to USB adapter, you should be just fine.
Feb 19, 2008 | Dell Dimension 4600 PC Desktop
Dell Inspiron 8100 Notebook Logo
315 people viewed this question
Alun Cox
