Question about Xerox Office Equipment & Supplies
Xerox workcentre pro c2128 fuser system error
SOURCE: Xerox Workcentre 24- Paper jam in the fuser
Shut down. Unplug!!! Remove fuser to remove jam. Fuser may be or be going bad.
Posted on Apr 22, 2009
checkitright
  • 1362 Answers
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Posted on Sep 08, 2008
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
  • 2072 Answers
SOURCE: I have Xerox workcentre pro
That is a software related error, You most likely need to reload the firmware, or replace the hard drive.
You can try disconnecting all the document feed and scanner cables then reseating them. Other than that, your looking at a software issue.
Posted on Jan 28, 2009
  • 4 Answers
SOURCE: what causes j 7 error copde in xerox workcentre
by replacing the drum unit or replacing the crum the code j7 will be cleared
Posted on Sep 01, 2009
HOW TO RESET ERROR CODE 04-562
Not a copier guy here BUT came up with this
1) From here
http://www.copytechnet.com/forums/xerox/43094-error-04-562-workcenter-pro-c3545-print.html
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. http://www.support.xerox.com/support/workcentre-pro-c2128-c2636-c3545/support/enus.html click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
How to fix xerox docucentre 2056 error 010-327
That error signifies a defective fuser, not coming to temperature. Replace fuser, part number 126K24980. See link below:
http://www.iteminconline.com/126k24980_126k24980-126k24981-126k24982-126k24983-126k24984-xerox-workcentre-5225-5230-fuser-110v-new.htm
Jun 10, 2014 | Xerox WorkCentre 52255230 Copier
I have a Xerox, Workcentre 580 and I am getting a fuser error
On this model, the heat roll has a temperature sensor. If the heat roll is worn and coated with toner, this will damage the sensor. Most common problem is this sensor goes out when a heat roll is badly worn. Circuit boards on this model are pretty reliable.
This sounds like a fuser rebuild.
Feb 16, 2011 | Xerox WorkCentre Pro 580 Plain Paper Laser...
What is cause of System Falt 4.361 on a Workcentre Pro C2128
Hi this is an issue with the drum motor if you turn off the machine and then turn it back on dose the error go away if not then you need to check the drum unit assembley remove it and see if you can turn the drum also check the drum motor to see if it is damaged
my advise would be to change the drum motor and check the drum unit for damage
Feb 02, 2011 | Xerox Office Equipment & Supplies
Printer is saying "fuser error- call for service"
You will have to replace the fuser unit.
Google a business called The Parts Drop and give them a call. They are roughly 200-250 dollars to replace
Dec 13, 2010 | Xerox WorkCentre Pro C2636 Color Copier
My Xerox Workcentre Pro C2128 has started printing images 1.5mm small than they should be. This is a critical measurement as we are an Artwork Studio and we need absolute accuracy. Is there a setting I can...
You can go into the driver and set the magnification.
But I am going to be honest. Xerox will tell you that is within specifications.
But go to the driver and try adjusting the size there.
May 19, 2009 | Xerox WorkCentre M20i All-In-One Laser...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
152 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
