Question about Husqvarna Sewing Machines
Lost operators manual for viking platinum 955e
Viking platinum 955e
2 Suggested Answers
  • 192 Answers
SOURCE: bobbin?
DO NOT RESET THE TIMING!! The timing is off on maybe 1 in 100 modern Husqvarna machines. For the user to change the timing is turning a simple fix into a complicated and expensive fix.
If the top thread is "looping up on the bottom" then you have a problem with the tension on the top thread. Here is what to check:
1. Thread the machine all the way through the eye of the needle. Don't go under the foot.
2. Pull the tread to the side. While pulling, lower the presser foot. You should see the needle bend as the thread gets tight. If not, you have no tension on the top thread.
3. With the bobbin in the case, hold the needle thread and turn the handwheel to bring the thread up. Watch through the cover to see if the thread passes over the bobbin from left to right. When it gets to the right side, the take up lever should pull the slack out and the thread should be pulled up. If it comes part way across but does not pull up, make sure the thread is in the take up lever. If you never see the thread, remove the bobbin case and turn the hand wheel. You should be able to see the hook pass behind the needle while the eye is still below the level of the hook. If the eye is above the hook as it passes the needle from right to left, then and only then consider timing the machine. If the hook passes above the eye but doesn't catch the thread (bobbin case out, needle plate on, presser foot down) you probably have a problem with your needle. Put in a new needle and make sure that the flat side is to the back.
99% of the time when a Husqvarna is not picking up the bobbin thread, something simple has been overlooked. Your symptom of looping on the back of the fabric indicate either a threading or tension issue in most cases, not timing.
Posted on Sep 14, 2008
Need a manual for Husqvarna Platinum 950E sewing machine?
Unfortunately, I don't know of any free sources of the manual. It is available here: http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm . Scroll down to the 64th item in the list. You can also check with a Husqvarna Viking sewing machine dealer in your area.
I hope this helps.
(I know that many dealers can get the manual for you. I was able to get a manual for an older Bernina serger for a minimal fee a few years ago.)
Nov 19, 2015 | Husqvarna Sewing Machines
Have a husqvarna viking platinium 950 e what cards will fit into it?
The Platinum 955E uses "d" cards for the embroidery function. You can find "d" cards on some of the auction sites. The machines is about 10-15 years old.
Dec 27, 2014 | Husqvarna Sewing Machines
My platinum 955e is sewing in reverse and I can't get it to go forward
have an authorized Viking repair dealer check it out, it may just need a thorough cleaning and minor adjustment.
May 14, 2014 | Husqvarna Viking 1
What year was the Viking 955E sewing machine discontinued?
I can't answer your question. But 90% of older machines (pre-1968) are better than ANY modern built machine on the home sewers market. Just saying. If you get the machine make sure it comes with the manual... then spend the $$ to have it completely cleaned and adjusted.
Aug 04, 2012 | Sewing Machines
Looking for a User's Guide and Handbook for my Husqvarna Viking Platinum 730 sewing machine. My manuals were destroyed in a flood.
You can find a similar manual from (http://safemanuals.com/user-guide-instructions-owner-manual/HUSQVARNA/VIKING%20190-_E).Hope you will be satisfied.All the best.
Apr 11, 2010 | Husqvarna Viking 1
Husqvarna 955E will not change stitch length. Is
Does the length on the display change or is it as if the buttons are not even working. If the touch pad is malfunctioning you will probably find other buttons not working. Try all of the buttons and see if others do not work. If this is the case, the keypad can be replaced.
Sep 02, 2009 | Husqvarna Viking 1
On 955E embroidery unit, the large black gear snapped
Welcome to FixYa. Hi - Viking has online tutorials for several of the 955E features, including embroidery.
Here is a link to the 955E tutorials. If the link isn't active, paste it into your brower window.
http://www.husqvarnaviking.com/us/6616_393.htm
As mentioned in the next paragraph, you can order a manual from your Viking dealer if you don't have yours. The Viking manuals aren't very expensive, and it is well worth having. You'll find detailed instructions for inserting and calibrating the embroidery arm, which happens everytime you insert the emb arm. See the Hints and Tips paragraph below.
If your machine is broken, the 955E Parts manual lists each part number in the machine, and the 955E Service Manual should provide instructions for repair. But because the 955E is not discontinued (as far as I know), the dealer might not be willing to sell you those manuals or order the parts you need. eBay often has Parts and Service manuals for sale for current model Viking machines, or you might be able to find them for sale on other web sites. Keep in mind that if your machine is still under warrantly, you risk voiding the warranty if you attempt to remove the covers and perform a "non-consumer" repair.
Some general hints and tips for inserting and removeing your embroiodery arm and navigating the Viking web site:
  • Always turn your machine off when you attach or remove your embroidery arm or when you insert or remove an embroidery design card.
  • When you insert your embroidery arm, insert an embroidery design card. When you turn your machine back on, you should see a message on the info screen that says something like "embroidery arm will move". Press OK, and the embroidery arm will calibrate.
  • After the embroidery arm has calibrated, place your hoop on the embroidery arm.
  • Look at each end of your embroidery arm - you will find a connector that must slip into a corresponding connector on the embroidery machine. This connector slides into a corresponding connector on the machine. The connector on the machine has a cover that slides open and closed. If it is closed, it you might not spot it right away. You must open this slot when you attach the embroidery arm - slide the embroidery arm straight back (not at an angle), so the embroidery arm connects to the machine securely. Although you might need to nudge the embroidery arm in place, do not force it!
If you or other viewers have a minute to rate my response (good or bad), your rating will help me to determine whether I unserstand your question and provided useful information. These ratings help me provide better service.
If you have additional questions or more information to add about your situation, please feel free to comment.
Cheers,' Ginny
Feb 10, 2009 | Husqvarna Designer I
Trouble with Viking 955E Embroidery Unit and Control Panel
Here is a link to the 955E tutorials:
Some general hints and tips:
The Viking site also has projects for the 955E that will help you learn to use some of the features - you can probably sew most or all of the free projects on the site, but projects for the 955E incorporate features on your machine that might be available on others. And look for the free designs!
Hope this helps get you started.  If you and other readers have a minute to rate this information (good or bad, or indifferent), your rating will help me determine if I understood your question and if my answer is helpful.
A few more recommendations...You can order a manual for your machine from any Viking dealer and probably online, and I recommend that you do. Your machine has some very cool sewing and embroidery features. I sold Vikings, so I can answer specific questions about many individual features, but Viking manuals are not expensive and can help you save time and avoid irritating problems.
If you have more questions, please comment and I will do my best to help you further. I am pleased to answer general questions about embroidery, if you want hints and tips or run into problems.
Cheers, Ginny
Jan 16, 2009 | Husqvarna Designer I
Sewing Machines Logo
52 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
