Question about Toshiba CF35F50 TV
TV Turns on but no picture
My Toshiba turns on and has a low buzzing sound without a picture. Can't seem to find the problem. No menu options come on the screen either. What do I need to do to fix the problem? Or is buying a new TV a better solution to my problem? Curtis
    Sergeant:
  • 337 Answers
The set needs service ,I dont think a new set is the answer a qualified tech should find the problem fast and inexpensibly.Get an estimate.
Posted on Sep 12, 2006
SOURCE:
TOSHIBA LED 46L5200U TV where picture stoped working and the volume is working
Check and replace its back-light inverter board. Contact any service technician. Gopakumar Gopalan Google
Feb 24, 2014 | Toshiba Televison & Video
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
I have a toshiba 43ax60 has sound no picture and the power light stays on when powered
you need to explore menue for tv options and select the proper input as well as other options.
Sep 17, 2012 | Toshiba 43AX60 43" Rear Projection...
Purchased Toshiba Regza 32AV615DB December 2010. On several intermittent occasions sound disappears and continuous buzzing noise takes over. Picture still on screen. Only way to rectify is turn TV off...
Sound carrier frequency are quartz locked in all modern TV. Your TV's sound freq: seems to be drifting. In the station tuning setup it will ask you Region ( Country ) Have you chosen correctly ?.
Mar 09, 2011 | Toshiba Televison & Video
I have a Toshiba 52HMX94 rear projection T.V., i've had it for 4 years, replacing bulb every year. I now have another new bulb, but when I turn on the T.V. i hear a buzzing noise from the rear, and then...
Your TV requires ballast power supply board that gives you buzzing noise when TV turns ON.
Ballast supply board is available in Part Store and replacement of that board requires expertise.
Jul 23, 2009 | Toshiba Televison & Video
Menu Screen turns on/off on its own...alsoTv video flips through
The front panel Tactile Switches need to be replaced. Replace them all. This should be the part #. 23344507. You can order it through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Jul 01, 2009 | Toshiba 32AF43 32" TV
No sound
Is your set plugged into a tv via scart sockets if so check the connections movement often unseats them and turns off sound and picture etc : If they are ok check that the sound is turned on in the menu and on the menu of the television set , low battries in a remote sometimes give the wrong signals and it causes many problems like this as it changes settings without you knowing crazy but true , when I was a field engineer I used to travel round an reset scores of sets Tv,s Video,s and other Infra red remote equipment with the same fault all because of low battries . If this dosen't work sorry to say a local service engineer to check out the set may be your best course of action .. Regards Vortash
May 06, 2009 | Cyberhome CH-DVD 300 DVD Player
Problems with sound that buzz/vibration sound My brand new Toshiba 40 LCD has similar occasional buzz/ vibration coming from inside TV
Same problem with my new Toshiba 55" LCD.
Also, after being on for awhile, the sound suddenly gets distorted in a fuzzy, echoie kind of way. Switching to a non-digital channel and switching back seems to make that correct itself. I may try a new HDMI cable to see if the problem goes away. Any other ideas?
Jan 14, 2009 | Televison & Video
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Zenith H2533Y TV Entering Service Mode
wHEN YOU GET THE MENU UP YOU HAVE TO HOLD THE MENU BUTTON DOWN UNTIL THE MENU DISAPPEARS THEN ENTER 9876 ENTER. YOU CAN ALSO JUST AUTO PROGRAM THE SET AND IT WILL COME OUT OF SERVICE MODE.
LADY TECH
Aug 31, 2007 | Zenith C27A24T 27" TV
Televison & Video Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
