Question about MSI Computers & Internet
Manual ms-7326 matherboard - MSI Computers & Internet
3 Suggested Answers
  • 62 Answers
SOURCE: ms-7326; i would like to receive
User manual you can find on Acer site, under:
Aspire T671 Aspire Desktop
Service manual:
http://elektrotanya.com/msi_ms-7326_rev_2.0.pdf/download.html
(Get manual link)
Posted on Sep 02, 2010
joecoolvette
  • 5660 Answers
SOURCE: Manual
I would like you to go here to Motherboards.org,
http://www.motherboards.org/mobot/manuals/MSI/MS-5185/
Where it states -> File: 5185v10.zipVersion:--Release Date:-- Download
I would like you to click on Download.
You will see a small window come up. Click on the empty circle to the left of -> Save
Unless, you have your downloads going to your My Documents folder (Start>My Documents) this will wind up on your desktop screen. It will be a yellow folder icon with probably -> 5185v10.zip <- under it.
Double-click on the yellow folder icon. You will see 6 PDF files.
5185-1.pdf, 5185-2.pdf, and so on.
To open them and look at them, you double-click on each one, one at a time.
Then in the File Download window, you click on Open.
In 5185-2.pdf, it shows you the Front Panel header, and where the Front Panel wires go.
(Not trying to insult your intelligence. The Front Panel is where your Power On button is. The Front Panel header is on the motherboard. A connector on a motherboard, is referred to as a Header)
Should somehow you can't download this PDF Motherboard Manual, I will try to explain the connections on the Front Panel header. Bear with me.
Viewing the motherboard with the processor up at the top, ram memory to the right, the Front Panel header is on the bottom right. It is the JFP2 header.
(The motherboard manual, clearly shows this header as being the JFP2 header. Then it states it's the JFP1 header. Believe there was a misprint. You'll know)
It is situated lengthwise up and down, parallel to the right side of the motherboard, with two rows of pins.
The pins are numbered 1 through 20. There are spots where there are No pins. Where there is no pin, I will state -> No connect
Starting at the top on the left side, and coming down.
Pin 18, 17, 16, 15, 14, 13, 12, No connect, and 10.
Starting on the top right side, and coming down.
No connect, 8, 7, 6, 5, 4, No connect, 2, and 1.
1.Pins 18 and 17 are for the Reset Switch
2.Pins 16 through 13 are for the internal speaker
3.Pins 12 and 3 are for the HarDDrive activity LED.
4.Pins 10 and 1 are for the Keylock Switch
5.Pins 8 and 7 are for the Power On switch
6.Pins 6, 5, and 4, are for the Power LED
Pin 6 is the Positive connection, (+)
This motherboard uses an ATX 20-pin motherboard power connector.
It is at the top of the motherboard, and goes across lengthwise.
There are 20 socket holes.
Pin 1 is on the top left. It uses an Orange wire. (3.3 volts)
Pin 10 is all the way to the right. It uses a Yellow wire, (12 volts)
Posted on May 10, 2009
Microstar MS-7326 PCI slots not working
Hello Daniel
- try another PCI slot
-check PCI settings in bios
- try any other PCI card
-update your bios .
Good luck : )
Jan 10, 2014 | Computers & Internet
Acer N1996 ms-7326
Hello visit acer here:
http://support.acer-euro.com/drivers/desktop/aspire_t671.html
For drivers and downloads.
Yes it is a MSI mainboard, but msi has build this for acer as a OEM board.
The drivers and software can only be found at the acer homepage.
Here is only drivers for windows vista operating system.
Good luck
Apr 06, 2013 | Soltek SL-KT600-C1L Motherboard
Looking for the msi ms-7326 ethernet driver
hi,
Click on the following link for driver: MSI MS736 Ethernet Driver
All the best
Ben
May 26, 2011 | Computers & Internet
I cant conecting seakers to matherboard i dont have instruction how to conect?
EXTERNAL speakers connect to the 3 coloured 2.5mm ports on the back of the motherboard, typically, you should only need to plug in the green plug in the green socket.
If you are trying to use 5:1 or more speakers, then you should consider investing ina PCI sound card instead
Jan 17, 2011 | MSI MS-6580 Motherboard
Ms-7326; i would like to receive a manual for the ms-7326 mainboard.
Service manual:
(Get manual link)
Sep 02, 2010 | Computers & Internet
LG IBM MS-6564 ver.1.0 Motherboard drivers
i need blog diagram matherboard lg ibm ms-6564 ver.1.0
Jul 13, 2009 | Computers & Internet
Need to connect adepters to matherboard from case(usb adepter)
Go to epox.com in the downloads.
I seen it it's in there.
May 01, 2009 | Computers & Internet
Pal MV500i.
http://www.smpcshop.com/DM-MV490E-DM-MV500E-DM-MV500i-DM-MV510E-DM-MV530i-DM-MV550i-p-7326.html
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Dec 05, 2007 | Canon MV500i Mini DV Digital Camcorder
Computers & Internet Logo
2,244 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
