Question about Lexmark Wheelwriter 15 Series II Typewriter
Strange letters Some of the keys have suddenly become inaccurate. For instance, if you depress "m" you will get @@ If you depress / you'll get _ Is this a call for replacement of the pinwheel?
  • Lexmark Master
  • 3,594 Answers
Try this hold the code key down press and release the L key type 001, release the L key this will reset the the language to english.If this works the pormanate repair is to replace the keyboard.
DickyO
Posted on Nov 06, 2008
    Scholar:
  • 183 Answers
Sounds more like the keyboard is going bad. If the printwheel was working fine before, replacing it won't fix this kind of problem.
Also check to see if the light besides " Lang", on the right of the keyboard is lit. If it is hold down the CODE key and hit the key with Lang printed on it. I think its the "L" key.
Another possibility is the keyboard is going bad.
Posted on Oct 30, 2008
The keys have suddenly become hypersensitive and the caps lock is stuck on. This happened after a battery change that I did with the keyboard face down on a table. I can get a single letter by barely...
I want to follow those steps but my spacebar is too sensitive, so it won't fit in the ~ key and I have the terrible HP G62 and I don't know how to remove the keys.
Nov 23, 2010 | Apple Wireless Keyboard
How do I chance the names on an NEC phone
NAME DISPLAY
NOTE: Display Dterm
A name with up to 16 characters can be entered to display the name on
other Dterm telephones when making a call.
• Press Speaker key, Receive dial tone.
• Dial the Name Assignment access code and receive special dial tone.
• Using the keypad, depress the key with the desired letter to display the
first letter on the key. The
display will indicate the
numerical designation.
Subsequent depressions will
advance through the letters
on that key. The Dial Pad Key
TABLE can be used as a
guide to indicate the key and
the number of depressions required to display numbers, letters, spaces
and periods.
• When the desired letter is displayed, depression of the Transfer key will
change the letter to a lower case letter (default is upper case). Depress
the Hold key to enter that letter and advance to the next entry.
• Repeat the previous two steps until the desired name is displayed and
entered
Apr 05, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Typewriter keys only print half a letter
In general, there are two possible causes for this symptom. 1. The ribbon is not fully in front of the typeface at impact. 2. The typeface is not in the proper position at impact. Depending on the model of typewriter there can be different causes for these two conditions, for instance, on a manual typewriter, that has a manual shift key, it is possible that the segment which travels up and down when depressing the shift, is not in the proper position, thus , when the typeface contacts the paper, the curvature of the typeface does not match the curvature of the platen. This can cause the top or the bottom of letters not to print. Likewise on an IBM Wheelwriter, it is possible for the platen itself to be loose which can cause just the top of letters to print. Observe the ribbon lift position and installation. Check the hammer, printwheel, platen,
Nov 13, 2009 | Office Equipment & Supplies
Broken keys?
The key levers and pawls are probably gummed up take it to a shop for a clean and lube.
DickyO
Jul 16, 2009 | IBM Office Equipment & Supplies
Right side of keyboard isnt working correctly.For instance if you hit the letter N a 3 will come up?
Numblock is probably on ,turn it off by pressing the numblock key again.
Probaly Fn+(another key ,the one that says numblock ,it's usually next to Scrolllock)
May 11, 2009 | Computers & Internet
Function needs to be pressed down to type letters
Make sure the num lock key is not depressed.
Dec 28, 2008 | Dell 0Y3740 Keyboard
Right side of keyboard letters prob.
you've got the number lock on.....find the key thats says num lock and press it once when you have this problem
Dec 09, 2008 | Compaq Presario 700 470024-192 Notebook
Keyboard disfunction
your hot keys are set that way goto search and find "hot keys" with out the ""
and you should be able to fix the problem
Nov 01, 2008 | Toshiba Tecra M2 Notebook
Lexmark Wheelwriter 15 Series II Typewriter Logo
83 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
