Question about Vizio XVT373SV 37 in HDTVReady LCD TV
Vizio xvt373sv wifi won't pick up any available wireless network.
My Vizio XVT373SV will not pick up any available wireless network. When connected by LAN it will show connected but when you go internet it does not work.
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: My vizio e420vl turned itself
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
Posted on May 29, 2011
  • 131 Answers
SOURCE: 32" vizio won't turn on
Hello; I am John at J D Electronics in Poland, Maine. I have now repaired 81 of this same model in my shop or PCB mail in's. The set may be dead always or work intermittently. There are 2 versions of this piece of junk, but I have only seen this one. They all have 2 to 7 capacitors that fail on the power supply board that are just above that red chopper transformer. The are labeled C233 and C234 and others. These first 2 are 3300 ufd at 10 volts and 105 C temp rating. You can buy these for about $1 each from Digi-Key Electronics plus $12 shipping. There are some cautions worth mentioning. Make sure the set has been unplugged for a day or more before starting the disassembling. It is VERY important to keep the set face down on a soft surface when doing ANY work on the set. This crappy designed set has a glass faceplate that will fall down if you don't have it face down when all the back screws are removed and it is very hard to put it back into position if it falls. The bottom plastic speaker strip has a million screws to remove both from the bottom edge. Then take out all the screws for the metal back and unplug the speakers. The connector wires to the speakers will not just pull off without you pressing on a side release pin for each of the 4 wire- Stupid design again!. If you are not able to solder or test these caps , you can send the board to me with $46.00 to replace and/or test up to 7 caps this includes USPS Parcel Post return shipping. I accept only cash or USA postal MO. There is NO Warranty on this repair. It is a better than 80% chance this will fix your set. You must call me first at 207 998 5687 EST 9-5 only. Good Luck! John
Posted on Sep 13, 2011
I have a Vizio XVT373SV. I have sound but no picture. I’ve done the flashlight test which reveals there’s picture but only with the flashlight. I’ve replaced the power board with no fix. On initially...
Please don't subscribe to the "let's try replacing this board" method of television repair. We see this all the time here. Take it to a television engineer, it is much cheaper to get correct diagnosis and replace one part, that to blindly change boards because you can buy them on eBay. The course to become a television engineer is two years full time.
Mar 02, 2018 | Vizio Televison & Video
Vizio xvt373sv how do I operate with no remote? I've turned it on with the side button... Now Vizio is blinking. Please help
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Dec 15, 2016 | Vizio XVT373SV 37 in HDTVReady LCD TV
My TV shows power on the Vizio at the bottom but it won't turn on and remains orange instead of turning white. Any ideas please
Is this the same main board as yours as shown in this thread?
http://www.badcaps.net/forum/showthr...light=SV422XVT
There are two fuses and 3-pin voltage regulator ICs that need to be checked and report the result as shown in this thread:
http://www.badcaps.net/forum/showthr...999#post300999
__________________
Never stop learning
Basic LCD TV and Monitor troubleshooting guides.
http://www.badcaps.net/forum/showthr...956#post305956
Voltage Regulator (LDO) testing:
Inverter testing using old CFL:
http://www.badcaps.net/forum/showthr...er+testing+cfl
Tear down pictures : Hit the ">" Show Albums and stories" on the left side
http://s807.photobucket.com/user/budm/library/
TV Factory reset codes listing:
http://www.badcaps.net/forum/showthread.php?t=24809
Mar 11, 2016 | Vizio XVT373SV 37" 1080p 120Hz Edge Lit...
Hello,My TV shows power on the Vizio at the bottom but it won't turn on and remains orange instead of turning white. Any ideas please
__________________
Never stop learning
Mar 11, 2016 | Vizio XVT373SV 37 in HDTVReady LCD TV
Manual, do you have it?
Download manual from manufacturer web site.
Sep 13, 2015 | Vizio XVT373SV 37 in HDTVReady LCD TV
What might be the problem on my Vizio XVT373SV HDTV that will not turn off and on properly?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 29, 2015 | Vizio XVT373SV 37" 1080p 120Hz Edge Lit...
My new VIZIO is connected to cable through a Comcast Xfinity cable box. I have not been able to get a picture for a large number of stations which I have aways gotten before. The name for the show on the...
If your tv set is good and you cannot get Comcast to help then you have to get rid of them. What are you paying them for? Try another set hooked up to the service just to make sure that it is on them to avoid any embarrassment.
Sep 15, 2017 | Vizio XVT373SV 37 in HDTVReady LCD TV
Vizio XVT373SV 37 in HDTVReady LCD TV Logo
328 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
