Question about Kyocera FS Office Equipment & Supplies
Kyocera fs-c5025 call service 0951:(printedpages)
Error code 0951 is the thing under the black toner, left hand side first grey cover, open and take out flat cables and plug in again. mine worked well afterwards!
ebenezer
  • 25 Answers
SOURCE: Kyocera Mita FS-3800
hello helpless try to clean the printer from smeared tonner and the transfer. the grey print could be as a result of printing using application sofware. make sure the tonner economy mode is not active form the application software,if it was turn it off and save, then reprint.
Posted on Aug 11, 2007
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
n25an
  • 622 Answers
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 24, 2009
SOURCE: Hi, moved my FS 3830 and it now says check waste
If you are in Ho Chi Minh City,you can go to Dinh Cao Trading and Service Company at 63 Vinh Vien street district 10 and we'll solve the problem for you.
Posted on Mar 16, 2010
Testimonial: "We took machine there this morning. Will lwt you know how it goes..."
I am getting error 7410:0283359 on the printer can you help
depending where you are in the world it might be call service
in the user book the trouble shooting section
just about every fault shown says call service
hand book ..68 pages
trouble shooting starts at 47
http://www.kyoceradocumentsolutions.com.sg/dl/wp-content/uploads/2014/11/FS-2000D_BOG_ENG_1.3.pdf
Apr 30, 2016 | Kyocera FS Office Equipment & Supplies
How to remove left and side casing from kyocera fs-c5025n please
FS-C5025N left cover removal.
1. Open the rear cover.
2. Open the top cover.
3. Remove the opening and closing axis from the main unit frame and then remove the top cover. It pry's out at the hinges.
4. Open the left side cover and then remove the one screw.
5. Remove the waste toner box. To remove waste toner box, press the lock lever in.
6. Remove the paper feed unit .
Feb 18, 2011 | Kyocera FS-5025N Laser Printer
Kyocera FS-2000D shows call service 7410:0130324
7410 is an error (all numbers following : is the number of pages printed.
- indicating the Drum Unit is not installed properly or you have a defective curcit board. Tyoically it is drum drum is not fully seated.
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmaly on the drum which is loacted behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
I hope this is helpful,
Shawn
Feb 07, 2011 | Kyocera FS-2000D Laser Printer
Call for service error 7410:0112053 on Kyocera FS3900 DN
most likely the drum popped out.
open the left side cover and remove the waste toner bottle..seated just above the waste toner bottle..press on the drum unit that sits above it..you will here it pop back into place .. if you hear it snap back it simply power off than back on printer....
if the drum is seated correctly.. than you need to replace the drum unit
Jan 12, 2010 | Kyocera FS-2000D Laser Printer
Black dots printing on left side of paper
dots are usually always caused by the drum..drums are very easy to replace..(you don't even need a screwdriver)
here's how..
remove the unit that the toner sits into..it's called a process unit..comes out as a whole with the toners...
next open left cover..
remove waste toner bottle. (drum sits right above it!!!
next remove drum by pushing on grey button and pulling drum
out the left side of the printer.
as far as the jam message you might need to replace tray feed tires located up under the machine
Jan 11, 2010 | Kyocera FS-3900DN Laser Printer
How to remove Kyocera FS-2000D drum?
open top cover then pull the developer unit (toner box ) then open left cover remove the waist toner box ..... there you can find a Grey color lock push and pull the full unit
for manual send mail to anantakumarjena0@gmail.com
Nov 30, 2009 | Kyocera FS-2000D Laser Printer
Change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Aug 27, 2009 | Kyocera FS-3900DN Laser Printer
Call service 7410:0037916
Hi, just swith off printer, and open left cover.Push drum unit(with grey lever on it -just by waste toner bottle) in the printer.Switch on printer.Drum unit was out of position.
Regards
Apr 08, 2008 | Kyocera FS-3900DN Laser Printer
Printing problems
Hi there check that it isn't the drum unit by turning the machine off open the top cover remove the toner and underneath you will have the dev unit unplug and lift out then remove the transfer tray (the one you open if there is a jam) open side door remove waste tank then you have the drum unit now to remove there is either a push button or a screw do either one that corresponds and check the unit. If there is a black line on one side the only way to get rid of the line is to replace the cleaning blade as this has worn. you can clean the drum unit cleaning blade it may only be toner stuck under the blade all you have to do is rotate the drum the opposite way of operation and if you have to hand a air line just give it a blast failing this it will defently need replacing.
Hope this is of some help
Please rate me
Cheers J
Dec 31, 2007 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-2000D
Hi, Sound like drum unit is out off position.
Switch off printer.Open left side door, remove waste toner bottle and push drum unit(with grej lever on it) in printer to proper position.If grey lever is not in proper position, drum will be not locked.Place waste toner bottle in position.Switch on printer.
Nov 02, 2007 | Kyocera FS-2000D Laser Printer
214 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
