Question about Brother IntelliFax-4100e Fax
Fax Problem I already submitted my problem, forgot to add my email address I have a Brother 4100E intellifax Super G3 machine. We replaced the toner and Drum and I still keep getting a message on the screen "change drum soon". What could the problem be? Thanks for your attention to this matter. TStrianese
    Problem Solver:
  • 8 Answers
Once you have changed the drum unit on Brother 4100 you will need to keep the front door open and then press the option button. Your dispay should give show you a drum change option. press 1 to change drum and the machine should show "accepted" after a few seconds. Afterwards, close the door.
Posted on Jan 04, 2009
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Brother intellifax 4100 e display says to replace toner but cartridge is not empty. Is there a reset for the toner?
There is no reset for the toner. It uses an optical system where light shines through the toner. Shake the cartridge gently left to right to even out the toner and try again.
Jul 01, 2011 | Brother IntelliFax-4100e Fax
How to change drum to a Brother Super G3 Fax Machine instruction state to change drum, and with door open, hit the clear button until "Replace Drum?" appears, then hit 1,,,,,,well there is no...
With door open, press "Options." Screen reads, "Change Drum?" Press 1 for yes. Screen reads "Accepted." Place drum/toner in, close door. Done!
Feb 03, 2011 | Brother IntelliFax-2920 Fax
How do I replace the toner in my Brother Intellifax 4100? The new toner cartridge just arrived, but this is the first time we have had to replace it.
Open the front of the machine. Lift and pull the whole unit (drum) out. Once you have it out it's pretty simple to remove the old toner from the drum and install the new one.
Jan 04, 2011 | Brother IntelliFax-4100e Fax
No manual to "Brother Super G3 336kbps IntelliFax-2920"
It is telling you the fuser unit needs replacement. Thats the heater that fuses the toner particles to the paper by heating them. If it cannot reach the correct tempurature the toner comes right off the paper.
So you will need to order a fuser wire kit to fix that error. That can be fairly expensive on a brother. I believe somewhere around $150 and up.
I can at least help you get a replacement manual. This link takes you to the downloads for your printer and you can then download the various manuals.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_top.html?reg=us&c=us&lang=en&prod=fax2920_us
May 13, 2010 | Brother IntelliFax-2920 Fax
Black streaking down one side
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Nov 07, 2009 | Brother IntelliFax-4100e Fax
My intellifax is pirnting all faded on the left side but not the right.
have you tried changing the drum imaging unit? It could either be a toner cartridge problem or the drum unit needing replacement. If it's new toner or new drum and this problem started since changing to the new, you may be able to get a replacement at no charge or a refund.
Hope this helps.
Nov 02, 2009 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Logo
482 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
